Head Gasket replacement on 2ltr 16v D8
sna400
Post by sna400 »
All
Just a quick question about replacing the head gasket on my 2ltr - can someone confirm the tightening torques and angle (in a haynes manual) 35nm stage 1, 70nm stage 2 the angle tighten to 160 degrees?? :shock: I'm not querying the nm settings - just the angle 160 degrees seems rather a lot on top of 70nm.
I'm hoping it's just a misprint and it should be 60 degrees - any help on this will be appreciated as starting to strip the car this morning to do it. :cry:
Cheers guys
Simon
D8 2.0 16v LX 406 Saloon
jasper5
Re: Head Gasket replacement on 2ltr 16v D8
Post by jasper5 »
Hi,
Tighten to 35nm
Then 70nm.
Then tighten 160 degrees.
This is correct for D8.
D9 is different.
sna400
Post by sna400 »
Thanks Jasper
It's lucky i have a 2ft breaker bar for the angle tighten then! :wink:
Simon
jasper5
Post by jasper5 »
They are very tight...
The D9 is 285 degrees :shock: :shock:
Good luck with it.
