Dual map ECU?
- OdinEidolon
Dual map ECU?
Hi all, I just read an interesting ebay auction on ebay.it.
The seller (a professional remapper) says he can install two maps on a single car, switchable in any moment with the car on.
He says he can obtain so by doubling the ECU eprom (I guess installing a parallel eprom board) and installing a switch.
One could then use an economic map for everyday driving and a secondary full power map for fun times.
Do you think this would be possible? I've never heard of anything similar.
H'e asking around 100€ for the job.
- lozz
Re: Dual map ECU?
idont see how tbh,
switch able at any moment with the car on
iwouidnt fancy that
im happy with just having the one map
iwouidnt fancy that
- OdinEidolon
Re: Dual map ECU?
Actually by doing some research something on this line can be possible.lozz wrote:idont see how tbh,
switch able at any moment with the car on![]()
iwouidnt fancy that
http://www.sr20tuning.com/theoryandpartsrequired.html
I've contacted the seller for more infos.
- lozz
Re: Dual map ECU?
will he give you anew car if it frys the ecu ? thats the question iwouid ask ibet he says noOdinEidolon wrote:Actually by doing some research something on this line can be possible.lozz wrote:idont see how tbh,
iwouidnt fancy that
iwouidnt let anyone loose near my ecu unless iknew they know what they was doing,
its not worth the risk imho not unless there was a guarantee on him paying out if out goes wrong
- OdinEidolon
Re: Dual map ECU?
Of course I will NOT let them touch my ECU even with a long pole. I'm just courious if this can be done. If it is, I may just gather some info and do that myself.lozz wrote:will he give you anew car if it frys the ecu ? thats the question iwouid ask ibet he says noOdinEidolon wrote:Actually by doing some research something on this line can be possible.lozz wrote:idont see how tbh,
iwouidnt fancy that
I've contacted the seller for more infos.![]()
For scientific purposes only, of course!
Re: Dual map ECU?
Any time is a fun time behind the wheel of a 406OdinEidolon wrote:Hi all, I just read an interesting ebay auction on ebay.it.
Never investigated in the issue - would be interesting what you find out
steve_earwig wrote:Ooh-er mrs.
- highlander
- PowerFlow Shill
Re: Dual map ECU?
Now if that quote doesn't appear in someone's signature (Discopol or Puggy), then I don't know what will...ToddM wrote:Any time is a fun time behind the wheel of a 406Especially with 180 bhp doggy-style
Re: Dual map ECU?
doggy-style indeed!
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
Re: Dual map ECU?
Now then Graeme you didn't check any of my posts before seeing that did you?highlander wrote:Now if that quote doesn't appear in someone's signature (Discopol or Puggy), then I don't know what will...ToddM wrote:Any time is a fun time behind the wheel of a 406Especially with 180 bhp doggy-style
it was done in a flash, sadly i have a mental image "Doggy-style" featuring our very own Doggy which im having difficulty shifting, it seems i will have to take my mind out and bleach the bugger to shift that one.
Re: Dual map ECU?
You're one sick puppy, Disco
Next, you'll be emulating puggy's penchant for waterproof atire.....
- lozz
Re: Dual map ECU?
oops im in the wrong forum
im off
im off
- OdinEidolon
Re: Dual map ECU?
So back to the topic, the seller basically says:
So it's up to this: anyone wanting to experiment? In the meantime I'll ask for a couple of pics and see if it is something feasible.
Two more questions:
how much would a spare ECU would cost, to experiment on?
Is the ECU plug and go? May I use mine on another 406 2.2HDi and viceversa, assuming I do not have the immobilizer alarm?
- The ECU eprom space gets doubled by installing 29F800 chip and removing the 29F400 which is commonly used
- A switch gets linked to the doubled ECU eprom letting the user select which information on the eprom are to be used
- The switch thus works instantly even with the engine on (this is something I could doubt of)
- En eventual OBD reader just acts reading one half if the switch is in a certain position, and the other half if the switch is in the other position
- Price is 80€ for unsoldering the 29F400 and soldering the 29F800, and 120€ for adding the switch (which I assume has its own board circuitry), for a total of 200€
- They have done this lots of time and can assure the process is 100% safe
Two more questions:
Re: Dual map ECU?
It's a long time since I studied this kind of thing, so things may have moved on, but I am doubtful about the safety of this strategy.
Changing to a bigger memory chip & futting in two maps seems OK, but this 'switch' sounds problematic, if it is supposed to be usable while driving. It has to change one address line to swap maps, but if it did this while this area of memory was being accessed, the results would be random.
Alternatively, if it interrupts the process while making the swap, what's you're engine doing, (or not doing), while this goes on?
Me? I don't fancy pioneering this one.
- plod
Re: Dual map ECU?
1999 D8.5 HDi GLX - Sold
Bring back my 406
- OdinEidolon
Re: Dual map ECU?
I agree too. The running switch seems strange to me too.
This is the foto he sent me. New Eprom on the left and switch on the right.
He answers all the questions promptly and kindly, and seems to really know his stuff. He claims they have done this many times before.
