2.0 turbo running problem
daviewonder
Post by daviewonder »
Hi all
I have an issue with the 2.0 turbo engine that I've fitted to my 205. It doesn't seem to want to start with out using 'easy start', when its idleing it's ok but if you press the throttle the revs drop and it nearly dies, I get the odd backfire too as I try to rev it. It's one of my projects that's nearing completion and I'm just getting it ready for the mot, I've not had it running much as the neighbours complained about the noise so this problems only just come to light.
Any ideas guys?
TRAVIS BICKLE
Re: 2.0 turbo running problem
Post by TRAVIS BICKLE »
There was another member on here that fitted one in a 306 that had very similar symptoms to yourself, i think it turned out to be crank sensor and plug leads.
Im putting mine into a Xsara VTR :mrgreen:
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
daviewonder
Cheers for the reply TB.
I've finally got to the bottom of it now and it turned out it was some damaged wiring going to the crank sensor.
All thats left to do now is get it mot'd :cheesy:
Wow, that must fly in the 205!
daviewonder
Captain Jack wrote:Wow, that must fly in the 205!
Dunno yet, I've only taken it round the block so far, it just wheelspins when I put my foot down :lol:
I've ordered a set of toyo proxes which should help me get the power down a bit better.
daviewonder
Quick piccy :cheesy:
