My d9 2.2 Sri decided to blow the rad today.
Looking to replace it asap and it looks a fairly easy job except how does the bottom hose come off? The hose clip looks different.
How much are radiators?
Will ones from other models fit?
2.2 petrol radiator change
Current car - Ph3 1.8 306
Re: 2.2 petrol radiator change
You've been looking for a project car, you say?
Well it's found you
There's a few HDI ones from 2.2s on the bay:
http://shop.ebay.co.uk/i.html?_nkw=peug ... m270.l1313
Check out how they look and compare to yours, they might be the same. Sorry I can't help you any further
steve_earwig wrote:Ooh-er mrs.
Is that the one with the spring clip on it? Pull off the clip, wiggle/pull out the pipe. You might want a new rubber ring for it.
Hold on 133054 - same as 607 & 607 new EW12J4. Not the same as 406 coupé
Don't suppose you know the part number for the bottom rad hose do you?steve_earwig wrote:Is that the one with the spring clip on it? Pull off the clip, wiggle/pull out the pipe. You might want a new rubber ring for it.
thanks for the help guys.
got the parts sorted
new bottom hose - 30.00
new rad - 108.00
406 forum - priceless!
new rad - 108.00
The bottle isn't 100% necessary (had debate with Krešo the mechanic about this one) but it's foolproof and saves having to watch the car all the time to top the expansion tank up as & when.
I still think my bottle was the better........
What, your "got to stand there holding it while the car boils over" bottle? Yeah, right
