Diff oil seal
moodybluetwo
Diff oil seal
Post by moodybluetwo »
Hi all..while I was changing the oil I noticed the drivers side drive shaft diff seal is leaking.Will the drive shaft pull out enough to change the seal without removing centre bearing? I am going to do a reccy tomorrow ( Sunday) then do it Tuesday if its straight forward. Your advice is welcome.
Bill
jasper5
Re: Diff oil seal
Post by jasper5 »
The whole driveshaft must be removed.
