engine overheat
Posted: Sun May 22, 2011 10:34 pm
by oxy
hi new here so go easy
the engine on my 2000 406 hdi 90 over heated today
there seems to be leak out of side of thermostat housing , out of a hole that looks as if a bolt went in , but when m8 bolt is put in it doesnt seem to take to threads
has anyone a pic of the thermo housing to see if we can work out what goes in it , or even if it is safe to just bung it up
thanks in advance
Re: engine overheat
Posted: Sun May 22, 2011 10:49 pm
by teamster1975
Welcome in oxy! :D
Where abouts is this hole? Around the edge or near the centre? If you could post up a photo it would be useful.
Re: engine overheat
Posted: Sun May 22, 2011 10:58 pm
by lozz
hi
Bleed screw missing perhaps,
pic :arrowd:
Re: engine overheat
Posted: Sun May 22, 2011 11:01 pm
by oxy
il try get a pic tomorow ,
its more to edge than in middle
Re: engine overheat
Posted: Sun May 22, 2011 11:15 pm
by lozz
Maybe someones cross threaded the bolt hole,
idunno realy,
if the Bolt-wont carnt got back in the only thing icouid sugest is Jb weld that stuff sets like concrete,
If you need anymore pics of one on the car give us a shout and iwill take some pics of my Thermostat housing on Mine,
the pic ive not long posted up is one iLiberated off Ebay sorry it didnt help much ,
Lozz.
!!!!!!!!!! ignore the above sugestion on the Jb weld dont block up the hole !!!!!!!!!!!!!!! :arrowd:
Re: engine overheat
Posted: Sun May 22, 2011 11:50 pm
by paulb2004uk
Is this the bit you are talking about - The blue bit is the bleed screw
Re: engine overheat
Posted: Mon May 23, 2011 12:03 am
by oxy
no its not that , its back towards the back of car from that
Re: engine overheat
Posted: Mon May 23, 2011 8:52 pm
by lozz
Hiya oxy,
ive had a look on mine today, and iknow what you mean now,
your thermostat housing will be the Alloy type not plastic,
the part missing will be a Brass head type bleed screw, with a alan key type head ,
Do not block up the hole the Bleed screw is needed, withought that youve no way of getting air out of the pipes and potentialy cook your head gasket !
grab one from a scrap yard best bet ithink,
