I'm after a bit of advice regarding glow plugs on a 2001 hdi (90).
I had a permanent Post Heat fault being registered and car going into limp mode.
I was told it was either Relay, coolant sensor or glow plugs. The relay and coolant sensor were replaced but the fault
remained. On Monday I bought a set of glow plugs from Halfrauds store and got our local Halfrauds service centre to
fit them.
Woooohoooo the fault cleared and car running normally.
Thursday morning, leaves work and gets about 2 miles and car goes into limp mode again.
Is it possible the glow plugs have failed or another fault causing the plugs to fail. Can't get to a diagnostics
machine until next week.
I noticed the plug nearest the air filter was loose, finger loose. Have tightened this but not made any difference.
Thanks for any advice
