Grrr... not starting
Posted: Thu Sep 28, 2006 6:03 pm
by Captain Jack
Hello folks,
This morning had a few words with my 406 Fawlty Towers style when it refused to start (2.1L TD). It was turning the engine over OK, but just wouldn't fire up! After leaving it for a a minute or so and trying again it started OK. The same happened at lunch time! Chug chug chug chug chug..... but no spark. Leaving it for a minute and trying again sparked it into life.
Any ideas what it could be? I am pointing the finger at glow plugs, which were replaced at around 60k (it's now 109k). Once started, it runs fine.
Any advice appreciated.
Posted: Thu Sep 28, 2006 11:47 pm
by Captain Jack
supafrisk wrote: How many miles has yours done again?
109k... It's really weird too. If it doesn't start within, say, 3 turnovers, then it definitely won't start. Have to switch it off and try it again. But when it does start, it's within 2 turns. Been doing it all day...
Another thing it did today is fire up and then die straight away.... very annoying!!!!
Posted: Fri Sep 29, 2006 10:38 am
Er, Supa it's a 2.1 Diesel :roll:
Someone else had this ages ago, have you done a search? I can't remember the outcome though, it does not realy sound like glow plugs, more a case of lack of fuel.
There is a way to bleed the pump on yours, that's what it sound like to me.
Posted: Fri Sep 29, 2006 11:19 am
by Captain Jack
Hmmm I'll do a search... Started first time this morning... stupid thing :(
Posted: Fri Sep 29, 2006 12:46 pm
by robconnors1977
is it key-pad or transponder chip - if it does not have a key pad try the spare key - its also worth noting sometimes the transponder aerials can fail which would give the same symptoms. - transponder systems were normally fitted s plate onwards although some late R plates also had them.
by robconnors1977
Posted: Fri Sep 29, 2006 1:40 pm
by Captain Jack
I don't have a keypad so it must the transponder chip in the key. I am still trying to work out what the pattern may be to get it going (I did take the key out yesterday and put it back in before it started). But as I said, it was fine this morning, which was very wet and cold so I am still at a loss...
I certainly hope it's not the fuel pump!! Those things are expensive :(
Posted: Fri Sep 29, 2006 2:19 pm
by robconnors1977
Might be worth fitting a new transponder aerial - they are only £15 from peugeot and a doddle to fit.
- They are fitted round the ignition barrell. - 5 mins to replace.
by robconnors1977
Posted: Fri Sep 29, 2006 2:24 pm
The key doo-dad is a good explanation.
Beware though cos them keys is well pricey.
Fecking immobilisers, I wish they hadn't got one because they allways play up in the end and let you down.
Imagine travelling across Europe and your immobiliser craps out in a little dusty village, be a bloody nightmare to sort out.
Posted: Fri Sep 29, 2006 2:36 pm
by Captain Jack
Welton wrote:Imagine travelling across Europe and your immobiliser craps out in a little dusty village, be a bloody nightmare to sort out.
Guess where I am travelling to next Saturday... :roll:
Posted: Fri Sep 29, 2006 2:41 pm
I know, exciting isn't it :cheesy:
Posted: Fri Sep 29, 2006 2:46 pm
by Captain Jack
Can't wait! The AA, here I come!
Posted: Sun Oct 22, 2006 2:20 pm
by Captain Jack
Welp, thought I'd do a little update. The problem again happened during my travels in Sweden. Had to take to key out and back in before it would fire up. So I am guessing it probably is something to do with the immoboliser. But since the problem is so rare, I won't bother with it until a million other issues get sorted. :cry: :frown:
