Water Temperature Gauge
uoapsdb
Post by uoapsdb »
As opposed to the oil temperature guage.
During a run, the water temp guage can operate normally for a while, then will display 0, then displays the temp again.
My immediate thought was that the water was a bit low.
Please can someone explain how to check the water level, I can't see a mark in the reservoir.
Should it be at the bottom of that plastic cylinder in the resrvoir, top, middle or what ?
Thanks Steve
Re: Water Temperature Gauge
theres a black marker if you look close you will see it,
its on the inside, its not Marked on the header tank its self :wink:
Temp going up and down couid be one of a few things,
: Airlock,
:Faulty Thermostat,.
: No thermostat, (someone Removed it )
: Faulty temp sensor,
