well i got some power loss - i feel the turbo is not as strong as before well, anyways checked the engine and found a hole (tore) in a pipe going to the engine and the other one is leaking ( to the cooler?) well i hope you can see it on the pictures
the spatter on the top ( i think its oil?)thanks to the leak
what can i do ? clean up the connections and fix it up harder ? and the hole/tore fix with big tape or it HAS to be renewed?
thanks in advance for your help guys
