HAS ANYONE CHANGED CLUTCH ON 406 HDI 110?
Posted: Thu Jun 30, 2011 1:56 pm
by no1toker
Hi folks as title says has anyone changed the clutch on a 406 hdi 100 2003 model! been quote 400 inc parts by kwik-fit so had a ring around can get a clutch kit for 100 so going to change it myself! done a couple clutchs before on vaux n fords! just want to know if if theres any think i should be looking out for or a certain wsay/order to do things! is it going to be anymore involved than the fords vaux's ive done in past! any input will b much appreciated! thanks in advance for any reply
Re: HAS ANYONE CHANGED CLUTCH ON 406 HDI 110?
Posted: Thu Jun 30, 2011 8:10 pm
by leehdi
I wouldn't use kwik fit while I've got a hole in my arse. They can't even regas aircon without blowing pipes.
Whats your email address and chassis number mate, I'll email you a guide
Posted: Thu Jun 30, 2011 9:23 pm
by no1toker
leehdi wrote:I wouldn't use kwik fit while I've got a hole in my arse. They can't even regas aircon without blowing pipes.
hi lee thanks for responce! only reason was goin to kwik-fit is its bout half a mile away the other nearest garage is 6-7 miles away and dont rely want to drive it further than i have to whiles the thrust bearing is knocking its ass off!
my email is kc_j(at)hotmail.co.uk a guide would b brilliant! thanks again lee
Posted: Thu Jun 30, 2011 10:01 pm
by Doggy
Excuse my 2p worth, but knocking could indicate a faulty DMF (dual mass flywheel). Most folks swap the DMF & clutch together, (some advocate solid flywheel conversion while you're at it).
If you're already aware, please ignore me butting in.....
Oh & welocme to the forum BTW
Posted: Fri Jul 01, 2011 5:30 pm
by RayneR
sorry for being such a noob but what's the dual mass flywheel ? it looks like the clutch ...
Posted: Fri Jul 01, 2011 6:55 pm
by leehdi
no1toker wrote:leehdi wrote:I wouldn't use kwik fit while I've got a hole in my arse. They can't even regas aircon without blowing pipes.
Sent it you now mate. Includes, removal and refitting of clutch, gearbox and flywheel
Posted: Fri Jul 01, 2011 7:10 pm
by highlander
RayneR wrote:sorry for being such a noob but what's the dual mass flywheel ? it looks like the clutch ...
The flywheel connects between the clutch and the engine.
It is a heavy piece of material which provides mass to compensate for the pulses of engine power between power strokes of the engine
Basically, it helps the engine to be smooth during the production of power.
A dual-mass flywheel is more commonly used in vehicles that produce a large amount of torque (read: turbodiesel engines), the idea being that the flexible compound that joins both parts of the dual-mass flywheel together will dampen the vibrations further than a standard solid flywheel would, thereby reducing wear on the engine, clutch, and gearbox. The problem with them is that they are more complicated, and over time the damping mechanism wears out, leading to excessive movement of the secondary mass, and the two parts of the flywheel will vibrate and cause the kind of problems the bloody thing was designed to solve.
Not all dual-mass flywheels suffer from these problems, and as time goes on the technology will improve, but on the 307, 406 and 407, people have reported the DMF is problematic, and it is possible to buy solid flywheel conversion kits for these cars.
Posted: Fri Jul 01, 2011 8:19 pm
by RayneR
Damn, i'm amazed how you guys can explain it in a way i can understand
Thanks for your explanation, i do know that it can be changed for a solid one .. which is the thing i will do when my clutch dies ( It's almost ( maybe in 1 year ? ) )
I Just changed the crankshaft pulley with a solid one ... my dual died ...which was changed for another scrapy dual one and died in the other day after
then we found a solid one which we couldn't find in our first attempt ...
Thank you so much
Posted: Thu Jan 26, 2012 4:12 pm
by caz8695
Hi I have just bought a 406 HDi 110 and the clutch is very high on the pedal & it seems to slip occasionally.
I was wondering if there is any chance of getting the instructions for changing the clutch too?
email address is
[email protected]
chassis number.... VF38ERHZE80831850
thanks in advance
