I have a T reg 406 2.0l 110hp HDI model.
Currently there are fumes leaking through one of the injectors; thus understand that the injector needs removal, cleaning, and the seal replacing.
I have tried to move the injector by using a screwdriver to lift the injector up, but it is very difficult; there has been slight movement, but not enough.
Are there any specific tools I should be using or a technique to be used? All 4 injectors were replaced 2 years ago.
Space is very limited on the engine block around the injector which makes it hard to locate and use the basic screwdriver.
I would welcome any suggestions you may have.
Regards,
Mike
