Knock Knock
Posted: Sun Oct 08, 2006 9:10 pm
by tux2006
Just a little thing i've noticed recently when pulling away from a standing start or slowing down to a stop I can hear a knock from the front of the car its only ever 1 occasionally two knocks, the girlfriend thinks its coming from the back its from the front but can sometimes sound like its coming from behind the driver
Does this sound like a suspension problem? I'm fitting new shocks and springs thur so i'll soon find out what the problem is just wondered if there was anything else obvious it may be :frown:
Posted: Sun Oct 08, 2006 9:19 pm
by chili
it could be drop links, just had mine replaced and that caused a knocking (more than 2 though)
Posted: Sun Oct 08, 2006 9:24 pm
by tux2006
yer I was thinking that but its not enough knocking I originally thought it might be the baseball bat i keep in the boot knocking around :cheesy: :lol: hmmm owell I check it out on thur
Posted: Mon Oct 09, 2006 5:31 pm
by dylann
I have the same problem on my 2.1 TD (1998) and have come to the conclusion that its coming from the back and that the problem is a worn mount on the rear suspension sub frame. I have checked all the links and bushes on the suspension and all are fine. Haynes has nothing to say on the matter. Anybody any ideas?
Posted: Sun Oct 22, 2006 8:32 pm
by Matt987
I've have recently just brought almost the same car a 97 1.8 16v and have what could be the same noise, if not I need to figure out what mine is!!!
It happens almost every time you pull away a clonck comes from the front drivers side sometimes loud sometimes very faint.
I was told by the guy I brought the car from that I needed to replace the Driveshaft!!!????
Does anyone know if this is a common fault, and could it be true???
If not what else might it be??
