Boost gauge - XUD11, where to route pipe?!
Posted: Mon Aug 01, 2011 7:55 pm
by CalamityJames
Hi all,
As I've come from the world of Japanese cars which have more spare holes through the firewall than a swiss cheese, I've just stumped myself on where to route the pipe for the boost guage, I can't seem to see ANYWHERE I can thread it through! (ideally on the drivers side).
Any ideas?
Cheers,
James.
Re: Boost gauge - XUD11, where to route pipe?!
Posted: Mon Aug 01, 2011 8:15 pm
by Bailes1992
In the floor pan on the passengers side, just before the carpet ends you will find a very handsome gromet :)
Posted: Mon Aug 01, 2011 9:07 pm
by CalamityJames
Bailes1992 wrote:In the floor pan on the passengers side, just before the carpet ends you will find a very handsome gromet :)
I'm gonna need a bigger piece of pipe then! :lol: lol
Cheers for that :)
Posted: Tue Aug 02, 2011 10:25 am
by Bailes1992
Cheers for that :)
Halfords do windscreen washer pipe, I just used that :lol:
Posted: Tue Aug 02, 2011 10:37 am
by CalamityJames
Cheers for that :)
Great idea! I'll pick some up on my way home, how much do you reckon I'll need? Or does it just come in a preset length?
Posted: Tue Aug 02, 2011 12:52 pm
by Doggy
I bought 5m of 3mm bore washer hose from my local factors to make a leak-off test rig, was less than £2 IIRC.
Anyway, don't faff about with grommets / hoses / gauges, just hook up your laptop to the ecu & Robert's your muvver's bruvver. 8) (just gotta stop it hurtling off the dash on roundabouts). :roll:
Posted: Tue Aug 02, 2011 2:25 pm
by CalamityJames
dogslife wrote:I bought 5m of 3mm bore washer hose from my local factors to make a leak-off test rig, was less than £2 IIRC.
Haha, a problem though, the boost sensor got replaced with the return to the Bosch pump! Plus PP2000 is ~£90 and a boost gauge is a mere £15 + hosing!
Posted: Tue Aug 02, 2011 7:48 pm
by Doggy
True. See if you can resynch your keys with a boost gauge.....
Posted: Wed Aug 03, 2011 10:04 am
by CalamityJames
dogslife wrote:True. See if you can resynch your keys with a boost gauge.....
Touché :lol: , although the keys work fine on the new ECU for some reason!
Posted: Wed Aug 03, 2011 9:12 pm
by Doggy
Sounds like you've had a series of good results there - well done. :cheesy:
Posted: Thu Aug 04, 2011 11:58 am
by Bailes1992
Immob has probably been baypassed when the bosch pump was fitted :)
