Tem porary problem with Pug 406
Posted: Fri Aug 05, 2011 12:45 am
by zocker
Hi Greetings and thanks in advance for your thoughts. My Pug (diesel) intermittently partially fails with some of the symptoms of a damaged engine: Rattling, slightly reduced power and some (small amt of ) white smoke on acceleration. The tacho stops working. If I stop the engine and restart, all the problems stop, only to appear at some random time later...is this an electrical prob of some sort?
Many Thanks!
Zocker
Re: Tem porary problem with Pug 406
Posted: Fri Aug 05, 2011 6:53 am
Need to know the engine type so that members can advise further, it's either the newer HDi or the older traditional XUD engine (1995 to 1998-ish).
Posted: Fri Aug 05, 2011 7:35 am
zocker wrote:All I know about the engine is that it is 1905 cc.
:wink:
White smoke is probably unburnt fuel, sounds like the ecu doesn't know where the engine's at - engine speed sensor?
Posted: Fri Aug 05, 2011 9:52 am
by zocker
Welly wrote:Need to know the engine type so that members can advise further, it's either the newer HDi or the older traditional XUD engine (1995 to 1998-ish).
Thanks! How do I tell which engine I have? Just says on the log book 1905 cc.
Z
Posted: Fri Aug 05, 2011 10:13 am
by Hangar18
Z
1905 cc - it's an XUD
Posted: Fri Aug 05, 2011 10:15 am
by highlander
That will be the XUD9 TE
http://www.pug406.com/wiki/index.php?ti ... -_1.9TD_8V
Your car will be a phase 1 (known on here as a D8), manufactured between 1995 and 1998. The engine is an 8 valve fuel-injected turbodiesel, and produces around 90 HP. You can probably run it on vegetable oil rather than diesel!
No idea what the problem is caused by, I'm afraid. Never owned any diesel.
Posted: Fri Aug 05, 2011 10:18 am
It'll be an XUD9TE then. It'll also say on your logbook VF38BDHX?80nnnnnn, the DHX is your engine code (=XUD9TE)
Posted: Fri Aug 05, 2011 10:20 am
highlander wrote:No idea what the problem is caused by, I'm afraid. Never owned any diesel.
If you think that's bad I've owned four and I still know bugger all about them :lol:
Btw the XUD9 is quite a simple set up with little to actually go wrong, just wait a bit and those with more experience will be along.
Posted: Fri Aug 05, 2011 11:21 am
by zocker
Thanks all! I'll await further assistance then!
Z
Posted: Fri Aug 05, 2011 1:16 pm
by Bailes1992
Right the fuel pump advance on the 406 is done by the ECU, an ill timed pump will blow out white smoke. Sounds like the ECU is mucking up the pump advance/retard?
Sorry I can't help more than that :(
Posted: Fri Aug 05, 2011 5:25 pm
by Doggy
The ecu gets it's actual timing info from the needle lift sensor on one of the injectors, (No. 2 I think). The same signal is used to generate the tacho signal, so it sounds like you have a problem with the sensor / wiring or maybe the injector.
Also, the timing control goes loopy if you don't have a good fuel supply - check fuel filter, in-tank strainer, look for signs of the pressurisation bulb going soft while the engine's running, or any leaks.
Posted: Fri Aug 05, 2011 6:02 pm
by zocker
Thanks! Where would you start to look? New or used ECU....BTW whats the ECU? Or maybe change over injector?
Z
Posted: Fri Aug 05, 2011 6:12 pm
by Bailes1992
ECU is the engine control unit. I belive StevieboyTD was running his 1.9 without his lift sensor plugged in.
