defapped & New file loaded... issues
As the title say really, defapped, and loaded 2 different variations of the defap 180 file to my 2001 2.2HDi Multiplexed 406, but the engine management light keep's coming up and the multi function display says "anti-pollution system defective" any idea please ?
TIA
TIA
To rebuild the impossible is possible by making it become a passion..... Oct 2001 406 2.2HDi 16v Executive..... A work in progress
Re: defapped & New file loaded... issues
Does it clear / work OK when you put the original back in?
Suggest you send me a copy of your original ecu file & I'll convert that to defap, (std power only), for the time being.
If you're quick, I might get it done later tonight - (leaving for a long weekend in the morning).
think i need to make a trip to northants
once the cars finished and you have sometime so you can have a play
please !!
No probs. I should be back Wednesday, working on the house the rest of the week/weekend.
Probably be glad of the distraction.
Did u get it all sorted bud? I cud put your old back on n then see what happens
Peugeot 406 2.2Hdi Coupe '02' Plate
Metallic Black(silver & black edition)
Manual, Rear Tints.
Manual, Rear Tints.
I think leaving the battery off all day has reset the ecu mate, took her for a good thrashing this morning and no messagesParm wrote:Did u get it all sorted bud? I cud put your old back on n then see what happens
Happy days
I will keep u posted bout mine
be careful with that heavy foot lol when u disconnect the battery what does it exactly do to reset the ecu?
Manual, Rear Tints.
Manual, Rear Tints.
on some cars yeah, but normally you have to leave it disconnected for a while for the residual power to drain.
Is it sorted now, Ian?
Re-mapped?
Re-mapped?
yeah mate all done
no issues since the battery was left disconnect for 6 + hours
Good news - well done Ian.
Thanks for the *** your a stardogslife wrote:Good news - well done Ian.
How are you disconnecting the battery? every time I disconnect my battery the alarm sets off and I CAN'T stop it. Takes a good 15 minutes (an eternity it seems like) of locking and unlocking the car to sort it!?
1996 406 Executive XU10J2CTE
1995 405 GLX XU7JP
1995 405 GLX XU7JP
ummm i am guessing yours is sensing a voltage drop and activating the alarm, it should only do this if the car alarm is armedHangar18 wrote:How are you disconnecting the battery? every time I disconnect my battery the alarm sets off and I CAN'T stop it. Takes a good 15 minutes (an eternity it seems like) of locking and unlocking the car to sort it!?
- waue1978
- HDi don't believe it!
Are there still no issues after a few days of running?iangt4 wrote:yeah mate all doneno issues since the battery was left disconnect for 6 + hours
Out of curiosity, do you get any noise or vibration under hard acceleration at low revs in 4th or 5th gear?
