turbo type
Posted: Sun Oct 15, 2006 2:27 pm
by podu
are there other cars which use same turbo as the 406.
guess have to get all numbers off turbo first,know its a garrett and thats about it without taking it off
Posted: Sun Oct 15, 2006 5:29 pm
by Foxy
Rover 220 turbos use a Garrett T25
Posted: Sun Oct 15, 2006 6:38 pm
by jason j
I thought the turbo we use is unique to the 406 due to mountings??
Posted: Sun Oct 15, 2006 7:02 pm
by jameslxdt
ive got a brand new (not exchange) garrett t2 turbo which is the same as the t25 i believe if you want it
Posted: Sun Oct 15, 2006 8:40 pm
by podu
so is it a t25 thats on the car as standard?
if so how much for it?
Posted: Sun Oct 15, 2006 9:17 pm
by jameslxdt
i have sent you a message
Posted: Sun Oct 15, 2006 9:47 pm
by niz406
jameslxdt wrote:garrett t2 turbo which is the same as the t25 i believe if you want it
The T2 is the default bearing housing used on T2's, T25's and T28's
The difference between the T2's is the diameter of the compressor wheels / covers 2", 2.5" and 2.8"
Peugeot use a non-standard exhaust housing unlike the rest of the world who believe in standardisation
Posted: Mon Oct 16, 2006 4:36 pm
by k3nny
Niz406 wrote:jameslxdt wrote:garrett t2 turbo which is the same as the t25 i believe if you want it
i always wonder,
So, if you can get a garrett t2's turbo will that means it will fit directly to pug 2.0 16v (non turbo)? when i mean directly is that you don't need to replace the pistons, rings and other things? i'm sure you still have to lower your compression though.
podu, could you let us know if you've fitted the turbo onto your pug? it seems pretty close to what i want to experience.
Posted: Mon Oct 16, 2006 5:50 pm
by podu
so if i get a t2 repair kit that should be ok for the one thats on the car!?
Posted: Mon Oct 16, 2006 6:24 pm
by niz406
Yes it will... its only the difference between the compressor wheel and cover that is denoted by the use of 5 or 8
Posted: Mon Oct 16, 2006 7:25 pm
by podu
ok thats great, many thanks. hopefully will have the car sorted next weekend cos down at weston this w/end,bit of a timeout from the car me thinks
Posted: Mon Oct 16, 2006 11:15 pm
by Captain Jack
Weston... hmm.. that's like... 40 mins from me :-)
We'll have to do a little meet at Weston Wheels if it comes back next year.
