Page 1 of 2
CHEAP ENGINE OIL 10W40
Posted: Thu Oct 06, 2011 11:56 am
by marco2002
Hi Everyone
Noticed the other day that asda have their own brand 10W40 semi synthetic oil for 10 quid on rollback (5Litres) its usually about £17.00. Has anyone ever used this stuff and is it any good. My only concern is i bought some cheap oil from GSF a couple of years ago and it made the 406 sound like a tractor the tappets sounded a lot more noisy got fed up with the noise and i switched back to the normal stuff quick as it was quieter. The cheapest engine oil i can get round here is over 20 quid. There is someone on ebay selling total quartz for £20 and free postage so that may be the best option? Any ideas or advice appreciated. Thanks
Re: CHEAP ENGINE OIL 10W40
Posted: Thu Oct 06, 2011 12:07 pm
by lozz
id go for the quartz stuff,
ive used the asda stuff but only in petrol engines, never had aproblem with it,
but ive not tried it in diesel engines, altho iknow alot of taxi drivers running on it so it might be ok
Posted: Thu Oct 06, 2011 12:37 pm
by jasper5
Look at the spec on the label if it reads ACEA A3/B3 API SL CF then it's good enough.
Posted: Thu Oct 06, 2011 1:07 pm
by marco2002
Hi
I'll have a look at the spec when i go to asda again tommorow. Thanks everyone.....
Posted: Thu Oct 06, 2011 2:40 pm
by ally406
I purchased a trolly load of Asda diesel mineral oil 15w-40 for use in my 405. I got it on special offer at 50p per 1L bottle. I do oil changes every 3,000 miles due to WVO use. The oil is supplied by Halfords who make very reputable oils. I've never had a problem with it in the 30,000+ miles I've been using it. If an oil is "diesel" spec, then the base oil that it's made from has to meet a higher quality requirement than that of general oil. Even if it were of lower quality, then the main difference is that it won't stay within specification for as long as a more expensive oil with more sophisticated additives. There is a school of thought that using a cheaper oil changed more frequently is better than using an expensive oil with extended intervals.
Posted: Fri Oct 07, 2011 7:41 pm
by Bailes1992
It won't cause a problem, just change it every 6,000 miles. Like you would any other oil ;)
But the engine might be a little louder and tap a little more. One way to find out?
I always been a lover of cheap ass 10w40 Semi synth and change it all the time (3,000 miles in my 406 on veggie).
But if you want a smoother and quieter engine a more expensive oil is the way to go. But you should still change it every 6k/6 months in my opinion.
Posted: Fri Oct 07, 2011 8:20 pm
by jasper5
Oil these days is usually suitable for petrol and diesel engines.
One thing you have to watch out for (well, I do as I have to service all kinds of vehicles) is the special oils for use with DFP equipped vehicles and the correct spec for VW/Vauxhall/Ford.
Posted: Sat Oct 08, 2011 11:13 am
by marco2002
Hi
Just bought the asda engine oil the specs are the same as my regular engine oil so. The oil only stays in there for 6000 miles which is about 12wks at the moment. I'll let you know if the engine sounds more noisy. But at £10 for 5 litres its pretty cheap. If i was only doing 8,000 miles a year i'd stick with the dearer oil. Looks like i'll be doing 18 - 20k this year.
Posted: Sat Oct 08, 2011 6:46 pm
by martint
mate oil is oil
its all the same providing you use the right viscosity/synth or semi synth..
hate all the crap about "use quartz blah blah blah!". im sure some o these guys get royalties from these companies.
Posted: Sat Oct 08, 2011 6:53 pm
by Bailes1992
martint wrote:mate oil is oil
Not at all!
Oil has different qualifications, much like petrol.
The difference is comes when the oil gets very hot, how does it break down?
How well does it keep the engine clean?
How long is it's 'Life'?
Lots of factors on oil, just change it regularly and you won't have a problem.
Posted: Wed Oct 12, 2011 1:49 pm
by leestudd30
So what grade/viscosity of oil should I be putting into my 97P 2 litre petrol?
Posted: Wed Oct 12, 2011 10:21 pm
by jasper5
leestudd30 wrote:So what grade/viscosity of oil should I be putting into my 97P 2 litre petrol?
10w40 semi synthetic or 5w40 fully synthetic.
Posted: Thu Oct 13, 2011 5:46 pm
by Bailes1992
Go for 10w40 Semi Synthetic.
Start using fully synthetic oil in an engine thats used semi synth all it's life and it will leak forever more!
Posted: Thu Oct 13, 2011 8:06 pm
by jasper5
Bailes1992 wrote:Go for 10w40 Semi Synthetic.
Sorry, but this is absolute nonsense!
Posted: Thu Oct 13, 2011 8:38 pm
I thought it was something along the lines of if you've been using mineral oil for many years and suddenly stick synthetic in your engine, the extra detergents will pick up all the deposits in the engine and clog oilways and stuff - this one hogswil too?
Then there's using an engine flush in an old engine and finding all the crap that it flushes out was what was stopping it leaking oil - hmm, I guess it's possible
There's also rubbing a piece of meat on a wart and burying it in the garden under a full moon...
