which filter housings are compatible with my 2.0 hdi (90)?
Posted: Thu Oct 20, 2011 6:03 pm
by martint
ive snapped my fuel filter top(one o the 2 pipe ends)& im wondering if anybody knows if any xsara parts or any other make/modelsare the same for my 406 hdi. just in case no-ones got a 406 for spares
Re: which filter housings are compatible with my 2.0 hdi (90
Posted: Thu Oct 20, 2011 7:13 pm
According to Service Box they always used Mahle but I was never sure. So...
This is a Mahle http://www.ebay.co.uk/itm/hdi-filter-ho ... 4aafcffab2
This is a Bosch http://www.ebay.co.uk/itm/PEUGEOT-406-9 ... 3a612e0b72
Which do you have?
Posted: Thu Oct 20, 2011 8:45 pm
by martint
mines is a bosch but does the filter housing from a xsara fit the same? i heard its the same 1
Posted: Thu Oct 20, 2011 9:30 pm
by john170277
would have thought so they are the same engine
by Doggy
I had a 99(T) Xsara HDi 90 with the Bosch filter, (distinctly remember putting a socket on the plastic hexagon, then chickening out when it wouldn't budge). :roll:
Doesn't gaurantee they're all the same though.
Posted: Thu Oct 20, 2011 9:42 pm
martint wrote:mines is a bosch
Now there it is, exactly what I was worried about - I can tell you what cars are likely to have the Bosch filter housing but I can't use Service Box to say anything for definite - I'm afraid you will have to look. I'm sure you've scanned down the ebay ad for the Bosch and seen Xsara and Xsara Picasso on the list already.
Let's see now, 190169 on anything DW10TD & DW10ATED (although I suspect early 'cos mine's a Mahle)
206
306 new
307
406 D8 & D9 Manual up to 9001 (2nd July 2001) Automatic up to 9337 (3 Jun 2002)
806
Partner/Berlingo
Expert
Xantia II
Xsara, Xsara II & Picasso
Synergie/Dispatch
C5
406 DW12TED4 until 9001
607 DW12TED4 until RPO 08938 (30 Apr 2001)
806, Expert, Synergie/Dispatch DW10ATED4 until RPO 08910 (2 Apr 2001)
C5 DW12ATED4 until RPO 8945 (7 May 2001)
I guess all we can surmise from this lot is you are moire likely to get one off a car built before the middle of 2001 than after. But you should still check before forking out any cash.
HTH
Posted: Fri Oct 21, 2011 9:09 pm
by plod
The Bosch one can be had for £54 from GSF and they gave me a 10% card for use on future purchases
