2.2 petrol jumping out of reverse
Posted: Tue Nov 08, 2011 11:19 am
by no2lurch
I plan to now change the gearbox oil on my 2.2 petrol at the weekend as my car jumps out of reverse from time to time.
The car finds all other gears fine, no problems.
while i'm under the car doing the oil, what else can i bee looking out for?
Re: 2.2 petrol jumpin gout of reverse
Posted: Tue Nov 08, 2011 11:28 am
by gumby6371
If you're draining the gearbox oil anyway have a good look at the bottom mount, if it needs changing you'll need to drain the gearbox so it's 2 birds with 1 stone.
Posted: Tue Nov 08, 2011 11:51 am
Jumping out of gear is nothing to do with the oil, it will more likely be excess engine movement pulling at the gear-change mechanism, or even the mounting for the gearbox itself.
Posted: Tue Nov 08, 2011 12:04 pm
by no2lurch
which mount do you think?
Posted: Tue Nov 08, 2011 1:07 pm
The favourite is the rear lower mount, on the HDi's the torque of the engine tears through the rubber over time and allows this movement but there is another one under? the gearbox I think. The power of the 2.2 petrol is likely to have the same kind of effect I think.
What you could try is opening the bonnet and carefully letting the clutch out (handbrake mega-on) whilst watching the engine movement - if it rocks about quite a lot then the mounts are worn.
Not saying this is deffo the problem but it's not the oil, the gear linkages are being pulled on by something I think.
Re: 2.2 petrol jumping out of reverse
Posted: Tue Nov 08, 2011 1:26 pm
by no2lurch
the engine doent rock about on idle but does seem to pull backwards when the handbrake is on and you try to reverse.
