406 hdi 90 injector woes and now anti pollution fault
Posted: Wed Nov 23, 2011 9:30 pm
Greetings folks,
first off, great looking forum. A testament to you all.
I have just bought a 406 hdi 90 rapier estate 2001 y plate off ebay. I test drove it when I went to pick it up and it all seemed ok. A bit more sluggish than my old 405 1.9td estate but I put that down to it being a heavier car. All went well drove it home a 100 miles no problems.
However (sigh), on getting home I realised the air re-circulator was on so I switched the heater (air-con with climate control) to suck in air from the outside. The cabin then started to smell of diesel. I had a look under the HDI shield on the engine and noticed the injectors were surrounded by a load of black coal looking carbon (bigger sigh). After a look on various forums including this one I concluded that the injectors were suffering "blow by".
I have removed them - took me all day. Then had them tested and cleaned - they are apparently ok. Cleaned up the holes as best as I could (still a few spots of carbon on the bottom of them) and refitted the injectors with new washers and tightened them down while engine was cold - I do not have a torque wrench so I just tightened them up.
Started the engine and a sprayed diesel all over the engine from a snapped fiel return pipe, I must have knoked it whilst trying to get the injectors out. I have replaced that part today.
So test drive tonight. All seemed ok untill engine got hot when smell returned. I took onto the motorway to warm it up properly thinking it may be the diesel I sprayed over the engine compartment. Under heavy acceleration the engine shut off and a yellow engine light came on the dash followed by an anti pollution warning on the trip computer display. Waited a minute and restarted and drove it home seemingly ok. Engine light on but no anti pollution warning.
Ok so my questions are:
Is it shagged?
Should I tighten the injector bolts down as hard as I can when the engine is hot? I am guessing it has all just expanded and the blow by has returned. I was frightened of doing this as I don't want to strip the threaded bar the bolts are on.
Does this car have a fap filter thingy as I am now thinking eeek more expensive problems.
Any other advice you folks think may be relavent would also be greatly recieved.
Regards
Rob
Is it shagged?
Regards
Rob
