Service box advice needed
gumby6371
Post by gumby6371 »
I'm still scouring breakers yards in the hunt for a replacement oil cooler but not having much look. I have located a 306 1.9td but need to check if it was fitted with the same oil cooler as the 406 1.9td, can someone check the part numbers on service box for me please ?
Common sense says they should be the same but it's too bloody cold and wet to scrape my knuckles at the breakers stripping the wrong part :cheesy:
Re: Service box advice needed
When you say oil cooler these don't have one as such, I think they have a wee jobbie that the filter screws on to with coolant pipes coming in and out. If so then yes, both 1103C9.
gumby6371
Post by gumby6371 »
That's the one Steve, thanks for the info
