maf sensor,symptoms and check.
grasmere59
Post by grasmere59 »
My newly aquired 2003 hdi 110 estate seems a bit down on power compared to my 2002 Rapier 110 i just sold,it goes o.k. but not as good as my old one and it isn't as economical (according to the mfd readout),i'm going to start checking stuff out but what are the symptoms of a dodgy maf sensor and how can i check if it's working correctly? :?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
nutski
Re: maf sensor,symptoms and check.
Post by nutski »
Try disconnecting the MAf and taking the car for a drive to see if it feels different, had to do this last night to the girlfriends 307 as the power was flat until the turbo kicked in, after disconnecting it was flying round again, MAF doesn't often flag faults which make it a bit more difficult to diagnose
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
piglet
Post by piglet »
Good question grasmere, is there a test method out there?
I have a 1500rpm 'flat spot' on my 90 which I am trying to get to the bottom of.
MAF connected or disconnected car seems exactly the same, is that right?
I have cleaned the MAF with injector cleaner, though it didn't really need it.
nutski
Post by nutski »
piglet wrote:Good question grasmere, is there a test method out there?
There should be a significant difference when disconnecting the, if it the same or there is an improvement when disconnecting I would think there is an issue with it.
2003 406 2.2 HDi SE
adam03031980
Post by adam03031980 »
My old maf was the same performance connected and disconnected so i bought a new on still the same power is great though car never lacks it but i have the same flat spot god knows why my 110 holds the revs when changing gear to keep it smooth but my 90 doesnt now sure if its the TPS or EGR could be anything on these damn things. I was told that if the maf is disconnected and the performance is the same then its working but how true that is i dont know.
