maf sensor,symptoms and check.
Posted: Thu Dec 29, 2011 2:39 pm
by grasmere59
My newly aquired 2003 hdi 110 estate seems a bit down on power compared to my 2002 Rapier 110 i just sold,it goes o.k. but not as good as my old one and it isn't as economical (according to the mfd readout),i'm going to start checking stuff out but what are the symptoms of a dodgy maf sensor and how can i check if it's working correctly? :?
Re: maf sensor,symptoms and check.
Posted: Wed Jan 04, 2012 1:59 pm
by nutski
Try disconnecting the MAf and taking the car for a drive to see if it feels different, had to do this last night to the girlfriends 307 as the power was flat until the turbo kicked in, after disconnecting it was flying round again, MAF doesn't often flag faults which make it a bit more difficult to diagnose
Posted: Tue Jan 10, 2012 2:49 pm
by piglet
Good question grasmere, is there a test method out there?
I have a 1500rpm 'flat spot' on my 90 which I am trying to get to the bottom of.
MAF connected or disconnected car seems exactly the same, is that right?
I have cleaned the MAF with injector cleaner, though it didn't really need it.
Posted: Tue Jan 10, 2012 2:55 pm
by nutski
piglet wrote:Good question grasmere, is there a test method out there?
There should be a significant difference when disconnecting the, if it the same or there is an improvement when disconnecting I would think there is an issue with it.
Posted: Tue Jan 10, 2012 9:31 pm
by adam03031980
My old maf was the same performance connected and disconnected so i bought a new on still the same power is great though car never lacks it but i have the same flat spot god knows why my 110 holds the revs when changing gear to keep it smooth but my 90 doesnt now sure if its the TPS or EGR could be anything on these damn things. I was told that if the maf is disconnected and the performance is the same then its working but how true that is i dont know.
