Engine Coolant Drain Plug?
Posted: Sat Dec 31, 2011 4:02 pm
Can anyone point me in the direction of where the coolant drain is on the 1.9td block?
I've flushed the radiator fine, as per Mr Haynes instructions but goes on to say to also flush the engine coolant, step 1 - remove drain plug. Can I find it, can I hell.
Any ideas ?
There are 3 drain plugs in the sump, would they run coolant through the sump to coil the oil sitting in there?
Any ideas ?
