Page 1 of 2
hdi fuel filter
Posted: Sat Jan 28, 2012 6:19 pm
by mjb
So how do you get at it? The Golf had a cap that came off with no problem, but the hdi90's doesn't look like it should - nowhere to grip. Do I need to put a spanner on the hexagonal bit at the top?
Re: hdi fuel filter
Posted: Sat Jan 28, 2012 6:22 pm
by Doggy
Yes,
carefully I gave up trying to undo the one on my HDi 90 after some gorilla tightened it up.
Re: hdi fuel filter
Posted: Sun Jan 29, 2012 9:26 pm
by mjb
Jebus
That was bloody difficult for such a simple job. Handy hints:
1. Take the quick-release connections off the top first
2. Use a 22mm socket - six sided - AND turn the fuel connections at the same time to distribute the pressure
3. The O-ring is at the top of the housing. Hard to spot.
4. Keep the bumpy ring
5. Give yourself plenty of time. It's an arse to get the lid back on
Re: hdi fuel filter
Posted: Sun Jan 29, 2012 10:55 pm
by scooby
i did that on mine and snapped the pipe off later realised you have to press it down as well as turn
Re: hdi fuel filter
Posted: Mon Jan 30, 2012 7:37 am
Buy a new housing AND filter - that's my top tip
Re: hdi fuel filter
Posted: Mon Jan 30, 2012 11:19 am
by mjb
Welly wrote:Buy a new housing AND filter - that's my top tip
The housing is 10% the cost of the car when bought from a factor!
Re: hdi fuel filter
Posted: Mon Jan 30, 2012 11:38 am
I thought they were £15.00? plus the filter cartridge.
So many people snap them it could leave you stranded unable to go fetch another one
Re: hdi fuel filter
Posted: Mon Jan 30, 2012 2:06 pm
by martint
Whatever you do,DONT apply pressure on the 2top tubes!!!
They snap REALLY REALLY easy. Ive done it twice now. Especially when theyre warm.
Best way :- WD40 (lots!), and 22mm socket as the guy above says.
Re: hdi fuel filter
Posted: Mon Jan 30, 2012 5:44 pm
by mjb
The lid on mine was threatening to round itself off unless I put pressure on the hose connections... Guess it's just a lose-lose situation on these things then
Re: hdi fuel filter
Posted: Mon Jan 30, 2012 7:41 pm
by plod
One of my pipes came off when doing the filter, but upon closer inspection it appears someone had glued it back on before
As it was a few weeks before my holiday down to Cornwall I played safe and bought a new housing
I think i've still got the old one with repaired pipe and brand new fuel filter in shed
Re: hdi fuel filter
Posted: Wed May 02, 2012 11:13 am
by scotty73
I just popped the one side of mine off and this thought just went through my head "Scotty your going to break this and you wont be going on holidays"
Needless to say the engine cover has just gone back on.
Re: hdi fuel filter
Posted: Wed May 02, 2012 1:19 pm
by lozz
upto now ive never had aproblem changing the filters on hdis,
its an easy job, once the pipes have been popped of the lid comes off easy,
Re: hdi fuel filter
Posted: Wed May 02, 2012 6:28 pm
by scotty73
lozz wrote:upto now ive never had aproblem changing the filters on hdis,
I got the left pipe off pretty easy but the right one looks a bit more awkward and i dont fancy being car less over the bank hol weekend, once we get back wether permitting i'll change it plus oil and oil filter... i popped a new air filter in today and the car seem to run better... Think i'm going round the twist cos surely a new air filter cant make it that much better? unless it wasn't changed at the last service when it says it was?
Re: hdi fuel filter
Posted: Wed May 02, 2012 6:40 pm
by trem1
this is from a 407 but still the hdi, does the 406 look like this
Re: hdi fuel filter
Posted: Wed May 02, 2012 6:49 pm
by scotty73
No trem where you got PUSH thats where the pipes come down from, think it's the same other than that.
The 407 looks a more sturdy setup to me.
