is my turbo knackered?2.0 hdi
Posted: Mon Mar 05, 2012 7:44 pm
by codgod
hi folks,im currently changing my dmf and im in the process of taking the car apart!.i took off the subframe today and i noticed oil all over the turbo and inside the turbo air pipe,quite a bit of oil was in the pipe is this normal or do i have a problem with the turbo.thanks steve.
Re: is my turbo knackered?2.0 hdi
Posted: Mon Mar 05, 2012 7:50 pm
by Bailes1992
Sounds like you've popped a boost hose or have a boost leak. You get a little oil in the inlet manifold and boost pipes. Totally normal!
Posted: Mon Mar 05, 2012 7:55 pm
by codgod
Bailes1992 wrote:Sounds like you've popped a boost hose or have a boost leak. You get a little oil in the inlet manifold and boost pipes. Totally normal!
hi bailes,thanks for your reply.whats a boost hose,does it need fixing?how do you fix it?have i lost power?
Posted: Mon Mar 05, 2012 8:21 pm
by Bailes1992
Is it a HDi 110 or 90?
HDi 110 has an intercooler (Radiator between the turbo and engine) the HDi90 does not. The turbo is plumbed straight into the engine.
Boost hoses are the hoses that carry pressure between the turbo and engine.
Posted: Mon Mar 05, 2012 8:25 pm
by codgod
Bailes1992 wrote:Is it a HDi 110 or 90?
it is a 110,what should i do?
