The issues are:
Barely any power in 1st and 2nd, especially when engine isn't quite upto 90C
Barely any power after 3500RPM, ever.
Noticeable hesitation when changing up a gear, or just accelerating in general (feels like excessive turbo-lag).
Sometimes pulls like a train once it gets going, other times more like a pony...
I know turbos 'do' lag but not like this, I have to be careful when overtaking or entering roundabouts etc as I have to plan for a good second or two of no power before it'll jump forward...
Anyway, took it for a drive with PP2000 to see what I could uncover...
TPS(APP) only reads 79% when my foot is flat, but if I operate it manually in the engine bay it reads 99%. Is that normal?
MAF readings look fine...
Turbo Actual/Turbo Expected are normally about right. It takes the turbo actual a long time to get to the value expected sometimes which seems to corrospond with the turbo lag I'm having. I also notice it can jump over the expected value under very harsh driving (ie, expects 2100MBAR it can jump to an actual pressure of 2200MBAR for a split second before levelling at the expected value). How does that sound?
I am also getting a brake switch error code on PP2000: (brakeerror.png) dont know how relevant that is...
Now the DEFAP thing, I uploaded a defap map which was created using my original ECU file, to my ECU, and the next day took it to a garage for actual DPF and CAT removal. Now I am getting a cat temp sensor error. I thought the de-fap map turned that lot off? or has the garage unplugged an electrical connector they shouldn't have? (caterror.png)
Thanks all
