Throttle position sensor?
Posted: Thu May 24, 2012 8:59 am
by STALLED
Hey,
I think I have a knackered TPS in my XU10 406 - where is it actually located and is it hard to replace as a DIY item?
Is there a ECU reset required?
Cheers guys,
Joel.
Re: Throttle position sensor?
Posted: Thu May 24, 2012 11:21 am
by jasper5
The TPS is nearly always located on the throttle body.
Should be a case of undoing a couple of screws and a wiring plug removal/refitting to replace it.
Not sure if a reset is required, I wouldn't have thought so, but electronics are not my strong point.
Posted: Fri May 25, 2012 1:56 pm
by craigtd
if its putting your eml on i would say you might have to clear the codes after the new one has been fitted but i have fitted new sensors before when the eml was on and i havnt had to clear the codes as there just stored in the ecu, so if when you fit it the light goes out all should be fine.
Posted: Mon May 28, 2012 6:12 am
by STALLED
No EML light - but a case of high idling and "jerkiness" when coming off throttle. Also hard to do a cold start!
