Dual Mass Flywheel
Posted: Mon Jul 30, 2012 6:48 pm
by Demondriver
Hi where is the cheapest place to get a dual mass flywheel? i believe my 2L HDI 90 has one and its knackered
Cheers in advance
Re: Dual Mass Flywheel
Posted: Mon Jul 30, 2012 6:49 pm
by lozz
hi
The Hdi 90s dont have dmf,
Posted: Mon Jul 30, 2012 7:41 pm
by Demondriver
ahh i was told they did, so its jut a standard solid fly wheel? where is the best place to get them from?
my usual supplier (euro car parts) doesnt list one on their website
Posted: Mon Jul 30, 2012 7:56 pm
by trem1
what is it your after ?? a clutch kit maybe or just a flywheel ??
try here
http://www.carparts4less.co.uk/car-parts
and yes its eurocar parts online only shop but cheaper, same parts but cheaper, ive had a very quick look and they have got clutch-kits for the 406 and Dmf's even tho yours shouldnt/wont have one
Posted: Mon Jul 30, 2012 8:35 pm
by gumby6371
What makes you think it's a knackered flywheel?
If it's juddery pulling away it could be fubard mounts, worth a look before dipping in your wallet, don't think solid flywheel failure is particularly common.
Posted: Tue Jul 31, 2012 9:31 pm
by Demondriver
thanks for all the replies, a few days after buying the car it seemed like the starter motor was goosed so swapped if for a second hand replacement and it was the same... 6 second hand ones later and it was no good.. it would start by bumping or putting it in 1st with ignition on and rocking it.
Then i got fed up after a day or two doing that so bought a brand new starter motor fitted that and its still the same but will only bump start now.
As if the teeth on the flywheel have gone and the starter has nothing to grab on to. Once its running its fine abit of a judder when setting off and the clutch is very noisey so whilst doing the fly wheel im going to do a full clutch kit on it.
So i will be needing a flywheel if thats a solid one of DM and also a full clutch kit
Posted: Tue Jul 31, 2012 9:36 pm
by lozz
Ibought a car from auction like that once,
i went through 10 starter motors and in the end i looked at the fly wheel
someone had had rammed a chizzel or summat in there to lock the engine up and broke a tooth off it,
