FAO Malachy... or anyone else who might know.
Posted: Tue Dec 19, 2006 1:24 pm
by niz406
What is the brand of that oversized comp head gasket you told me about?
Cos...????
Where can I get them from, and where can I get some ARP headbolts?
Cheers!
Re: FAO Malachy... or anyone else who might know.
Posted: Tue Dec 19, 2006 3:40 pm
by Malachy
niz406 wrote:What is the brand of that oversized comp head gasket you told me about?
Cos...????
Cheers!
the gasket is made by Cometic,
can get it from most pug tuners hiflow/longmans/205parts/QEP
these will most likely be able to supply you with the arp bolts too. Although i have never heard a need for arp headbolts on an xu before, its common for conrod bolts though (only in high revving 8k+ apps though)
youll need the 86mm bore gasket,
contacts:
QEP:
http://www.q-e-p.co.uk/
Quality Engineered Products
Unit 10, Old Kiln Works
Ditchling Common Ind. Est.
Hassocks, West Sussex
BN6 8SG
t: 01444 243720
[email protected]
Longmans:
Richard Longman & Co.
5, Airfield Road
Airfield Way Industrial Estate
Christchurch
Dorset
BH23 3TG
Tel 01202 486569
205 parts:
http://www.205parts.com/
Unit 6 The Hacheries,
Harborough Road,
Kibworth,
Leicestershire
LE8 0RF
0116 279 205 7 (Unit)
07749 286334 (Paul)
07737 950820 (Michael)
Hiflow heads
http://hiflowheads.co.uk/
Hiflowheads
Unit J1
Gilmerton Estate Athelstaneford
East Lothian
EH39 5LQ
Office Phone /Fax: 01620 880763
Mobile: 07748 803660
Email : [email protected]
Good luck QEP have a very good record so would be my first stop:P
Posted: Tue Dec 19, 2006 3:47 pm
by niz406
Cheers Matey,
I understand they are 86mm but are they the thicker gaskets with copper pipe or bar cyilinder cores?
Posted: Tue Dec 19, 2006 4:02 pm
by Malachy
niz406 wrote:Cheers Matey,
yep you can basically get any sort you want, cometic make copper/kevlar/horsehair gaskets in pretty much any thickness you request too
go here
http://www.cometic.com/catalogs/AutoCat04.pdf
thats the auto cat
have a browse through page 30 has the xu10 gaskets they are Multi Layer Steel listed in the catalogues but i am certain you can get others, my friend has a kevlar one on his 205tt
Although that is alloy head > alloy block with liners
cometic wrote:
MLS (Multi Layer Steel)
The Cometic MLS gasket is comprised of three layers of
Stainless Steel. Cometic uses Stainless steel for increased
strength, it’s ability to rebound and corrosion resistance. The
outer layers of the gasket are embossed and coated on both
sides with a flouroelastomer rubber based material (Viton)
designed to meet the demands of a variety of harsh sealing
environments, load conditions and surface finishes. The Viton
coating is heat resistant to 2500C or 4820F.
The center or shim layer of the gasket is comprised of an
uncoated Stainless Steel layer, which can be varied to
accommodate multiple thickness requirements. The MLS
gasket is ideal for both aluminum heads to cast iron blocks and
aluminum heads to aluminum blocks.
The composition of MLS will also withstand the shearing forces created by aluminum heads on cast iron blocks. No re-torque is necessary. By design the MLS gasket promotes an even torque load across the sealing surface allowing for less clamping force and meaning a measurable reduction in bore distortion.
Available thickness: .027", .030", .036", .040", .045", .051", .060", .065", .071", .074", .120"
Cometics uk office is
[email protected]
Cometic Gaskets ltd
PO Box 8819
Colchester
Essex
CO1 1WZ
tel: 01206 561144
fax 01206 561155
Posted: Tue Dec 19, 2006 4:31 pm
by niz406
Well called all of them...
QEP were a great help, and the lady that answered the phone sounded so sexy... she was ever so helpful and polite ! They are emailing me a quote later today
As for the other three, called them only HFH didn't answer and the others couldn't help me, apparently Longmans use Peugeot Sport gaskets for their race tuned engine, @ a cost of about £500 per gasket ! w0w ! !
But QEP have my vote, just waiting on their response !
Posted: Tue Dec 19, 2006 4:37 pm
by Malachy
niz406 wrote:Well called all of them...
QEP are very highly regarded in 205 circles for good reason ;)
they also sponser the 205gtidrivers forum
i expect the gasket will be about £80-£100
