bad rattling noise from engine.2.0 hdi
rwb
Re: bad rattling noise from engine.2.0 hdi
Post by rwb »
My bet is the bottom pulley has started to disintegrate. Mine did something similar; strands of metal ribbon stick out of it and catch, causing this type of noise.
I ran with mine like that (although not as bad) for months. However, the received wisdom on here is to fix this immediately because if it gets worse or fails completely then it can take out your cambelt with it and then the show's over.
Busman
Post by Busman »
Yes, check the alternator drive belt urgently. If its frayed it would cause this noise, and when it goes it could destroy the engine as it can take out the cam belt. A new one should be £10ish
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Busman
Post by Busman »
Busman
Post by Busman »
Oops, something strange is happening to the board, Codgod managed to post the same thing 4 times, I deleted 3 of them and... this one went too. Sorry 'bout that. Oh, also the board's not even recorded that I did anything and it's still showing on the front page :roll:
Anyway yes, check belt and pulley as above. If the belt breaks or the pulley drops it, it'll probably end up taking the timing belt out. Not necessarily terminal but you'll at least need 8 new rockers.
Wonder how many times this'll post :frown:
codgod
Post by codgod »
hi folks thanks for reply,i checked the drive belt when i stopped it wasnt frayed it is worn as i can see slight airline cracks in it.steve
codgod
Post by codgod »
hi again,if anybody lives close to me and wants to pop over and and have a look i would be very grateful and a slab of beer would be in return.steve
Your best option is to take the Auxbelt off:
and turn each pulley -see if they turn freely and check for play,
Obviously Crank pulley wont turn freely by Hand but if its failing you will feel Movement in it,
ithink they give off a Brown rusty Dust too if there on the way out,
codgod
Re: bad rattling noise from engine.2.0 hdi.FIXED
Post by codgod »
HI FOLKS,IVE FIXED THE PROBLEM.YES IT WAS THE PULLEY GOT 1 OFF EBAY FOR £44 IT WAS A FEBI MAKE ALSO REPLACED BELT AND TENSIONER DAYCO MAKE £47.THE JOB WAS REALLY EASY TO DO SO DONT BE AFFRAID TO DO IT YOURSELVES IF ANYBODY ELSE IS THINKING ABOUT IT.THE INFO ON HERE WAS REALLY HELPFUL.THANKS GUYS.
