Page 1 of 2
406HDI Remove A/C compressor & fit smaller belt?
Posted: Wed Nov 28, 2012 1:19 pm
by allypally
Can i remove the A/C compressor and fit a smaller belt? Would i need new idler rollers or tensioner etc? My workshop manual does not show a diagram of layout without A/C.
Re: 406HDI Remove A/C compressor & fit smaller belt?
Posted: Wed Nov 28, 2012 2:31 pm
by lozz
Posted: Wed Nov 28, 2012 2:32 pm
by lozz
bottom pic :arrowu: is none/aircon
Posted: Wed Nov 28, 2012 10:28 pm
by Busman
So, it looks like the answer is yes you probabley could, but why bother, as opposed to just leaving it on there and not using it?
Posted: Thu Nov 29, 2012 10:01 am
by allypally
Thank Lozz and Busman. Looks like the center pulley is in different position and additional one at bottom. Looks like i would need two pulleys and a new belt and then still not sure if i could make them fit. Only thinking of it now as i could do with changing the belt anyway and i am worried about compressor seizing on me.
Thanks again.
Posted: Thu Nov 29, 2012 10:29 am
Any better?
The idler in the same place looks a similar size but has a different part number.
03 5703A5 COLUMN SCREW (about 4 quid)
06 575196 ROLLER (about 30 quid)
07 575156 ROLLER (must be gold plated)
The tensioner is the same.
You should be able to pick the rollers up from a factor's a hell of a lot cheaper...
The belt depends on an RPO (something to do with the alternator):
5750XT DRIVE BELT K6 LE 1468 - UNTIL RPO 09337
5750WH LE 1468-K6 - SINCE RPO 09338
Err, isn't the 1468 the length :? Maybe the width is different. Or something.
Posted: Thu Nov 29, 2012 10:53 am
Oh crap, I was just having another look and I've spotted that the alternator brackets are also different (where the rollers go). 5706E7 80 quid on Service Box :|
Here's one http://www.ebay.co.uk/itm/Citroen-Berli ... 2325b54093
Posted: Thu Nov 29, 2012 11:24 am
by allypally
Thanks Steve_earwig, Just what i thought not as straight forward as one would expect. A few quid in parts as well. I may try a breakers for the complete assembly.
Do you know what chance there is of the A/C compressor seizing with no oil in it and just leaving it on car without using A/C as it stopped working 18mths ago?
Obviously pulley still running all the time but not the compressor running without the clutch engaged.
Posted: Thu Nov 29, 2012 11:30 am
I've never heard of one seizing, I can't see why it would but that's not saying it's impossible, just I don't know.
I reckon breakers too, the bracket is a common part (I could do a list...)
Posted: Thu Nov 29, 2012 11:40 am
by allypally
Thanks again Steve_earwig.
Posted: Thu Nov 29, 2012 2:02 pm
by lozz
The A/c compressors can lock up.
but ithink you will notice warning sighns before it doing so,
if its not noisy and theres no sighn of belt fray, iwouid leave it alone tbh.
Posted: Thu Nov 29, 2012 6:54 pm
steve_earwig wrote:(I could do a list...)
1 document(s) found for Partner (M59)
2 document(s) found for 206
1 document(s) found for PARTNER
1 document(s) found for 806
2 document(s) found for 406 (RESTYLING)
4 document(s) found for 306 (RESTYLING)
1 document(s) found for EXPERT
1 document(s) found for BERLINGO
1 document(s) found for XSARA II
1 document(s) found for DISPATCH I & II
1 document(s) found for BERLINGO (M59)
1 document(s) found for XSARA PICASSO
1 document(s) found for C5
1 document(s) found for XANTIA II
1 document(s) found for SYNERGIE
I started checking but it looks like it's going to be any one of these with a DW10 but without air con.
Posted: Thu Nov 29, 2012 8:44 pm
by jasper5
The bottom pic looks suspiciously like the arrangement on my Expert van 2.0 HDi 2004 and the arrangement in your post, Steve.
I can have a look in the morning for the belt length if that's any help....I have a couple of spare ones lying about.
Posted: Thu Nov 29, 2012 9:53 pm
If it doesn't have air con it will be the same. I think that's the length there, 1468? But I don't know what the difference is if the lengths are the same, I'm just guessing width. Or it might be the ribs (to excite? :shock: )
I was actually wondering if it would be worth using the old larger roller, with the 2nd smaller one and then measuring it all & buying a belt of the appropriate length. Or would that be a PITA?
Posted: Thu Nov 29, 2012 10:24 pm
by jasper5
Yeah, 1468 sounds familiar, they are the same width ....K6 is their listing....6PK is the number of ribs, so K6 will be 6 ribs as with the 6PK (the listing i'm familiar with.)
Mine is without A/C.
I don't know about the bigger roller, but the lower one doesn't seem to do a whole lot.....might be possible to remove the bigger roller and use a shorter belt.
