more V6 power
Posted: Wed Jan 03, 2007 8:40 pm
Found this posted by Roy on the coupe forum, peoplemay find it interesting - get more power from the 406 V6
ive been speaking to DP Engineering and they have given me a comprehensive list of things that are needed for the coupe to turbo it !
this is for the v6, the most expensive part being "the claw" the complex manifold
you would need to source an aftermarket ecu and get someone to make custom intercooler piping and a down pipe.
costs would be less if you could source a 2nd hand turbo, or import from the usa
Garrett GT3071R ball bearing turbocharger turbine a/r .64 £1,026
Garrett waste gate actuator T2 / T25 0,3 - 0,7 bar £84.10
DP Garrett GT-series adjustable actuator mounting £26.42
Stainless V6 24v turbo exhaust manifold 'the Claw' £1,332
Stainless 3" flex pipe £45.87
Stainless braided oil feed line £60.53
T-piece; pressure switch dual outlet (oil pressure switch and feedline connected on switch position) £12.08
GT25-28 / TD04 Oil drain flange + gasket £14.10
Hose connection for oil drain flange £2.49
Oil and heat resistant hose 100 cm £16.81
Forge dual piston dump valve £107.60
TOTAL
£2,730.01 Inc Vat & Shipping
Garret GT30R Turbo
THE CLAW !
The Conversion on a 406 saloon
Please note ive just knicked this from roy, if he gets annoyed with me im sure hell tell me
TOTAL
Garret GT30R Turbo
THE CLAW !
