2.0 HDI not starting
Posted: Mon Dec 24, 2012 1:45 pm
by jbh325i
right where to start..
got this from my brother last night car has never let him down went to collect it and it started instantly after the first heat.
drove it home no problems and was out in it last night and it never gave me any issues.
parked it up at around 11 last night went out to it at 1 o'clock in the afternoon and its refusing to start.
It has a qtr tank of fuel but when I take the feed line off the filter and crank it over its not giving me any fuel through.
any ideas? I need to use the passengers door to lock and unlock it as the drivers lock just spins could this be related ie imobilisser kicking in?
my brother never locked the car so wondering if this could be the issue.
Re: 2.0 HDI not starting
Posted: Mon Dec 24, 2012 1:49 pm
by madmadmax
this may be the in tank pump if you lift the back drivers seat there should be a black disk under it is the in tank pump
the key spinning in the lock is an anti theft feature you will need to take the lock to a lock smith and get it adjusted
Posted: Mon Dec 24, 2012 2:14 pm
by jbh325i
madmadmax wrote:this may be the in tank pump if you lift the back drivers seat there should be a black disk under it is the in tank pump
right after a bit of google searching I was starting to thing the low pressure pump so ive got the rear seats up and im into the LPP and when turning on the ignition and crancking it over its not givving me fuel. Ive spoke to my brother and he says this was replaced a year ago by a garage. there's 4 wires running to the top of the pump 2 I presume are for the fuel gauge the other 2 will be for the pump. which ones are which so I can test for power.
James
Posted: Mon Dec 24, 2012 3:22 pm
Fill the lock up with WD & leave it a while, it might free off.
As usual Pug don't do colour codes so you'll have to squint at the tiny writing on the wires, I can't tell you which way the plug is wired up either
1 433 : Fuel gauge 1 info
2 1201 : fuel pump control
3 blank
4 M120 : Earth
5 434 : Fuel gauge 2 info
Don't forget to check if it has the safety cut off switch on the suspension tower nearest the battery...
Posted: Mon Dec 24, 2012 3:26 pm
by jbh325i
steve_earwig wrote:Fill the lock up with WD & leave it a while, it might free off.
3 blank
4 M120 : Earth
funny enough I was just away to post up.. checked no power to the pump went under the bonnet as googled for the inertia switch and as you say on the suspension tower pushed it and heard a click.. and away she goes
Posted: Mon Dec 24, 2012 4:15 pm
Splendid
They don't all have them (neither of mine did) so they're often forgotten.
Posted: Mon Dec 24, 2012 4:33 pm
by jbh325i
yea now ive got it running ive discovered it wont move due to a broken front spring on the passengers side right next to the switch.. at least I know whats tripped it
Posted: Mon Dec 24, 2012 7:04 pm
Oh ffs
Did it do much damage?
Posted: Mon Dec 24, 2012 9:52 pm
by jbh325i
steve_earwig wrote:Oh ffs
not sure yet called it a day after that.
ive ordered a spring and ill hopefully get that between Xmas and new year
so will get a look once that's arrived.
the spring on the drivers side was changed for its MOT last week so I should have known this one would be due to go
Ive got my mates 320d to run the now thankfully
Posted: Thu Dec 27, 2012 10:09 am
So the snapping spring took out the inertia switch - that might be a first here
Get a garage to change the spring unless you're very competent and have the right kit and room to work safely.
Posted: Thu Dec 27, 2012 1:44 pm
by jbh325i
Welly wrote:So the snapping spring took out the inertia switch - that might be a first here
Ive changed a few springs in my time and have access to a hydraulic spring clamp so ive no worries there
Posted: Thu Dec 27, 2012 6:35 pm
I thought I should say something because some people don't really appreciate how dangerous a spring-change job is without the right knowledge and kit.
Posted: Thu Dec 27, 2012 10:47 pm
by jbh325i
Welly wrote:I thought I should say something because some people don't really appreciate how dangerous a spring-change job is without the right knowledge and kit.
No I would agree with you I seen a boy lose 2 of his fingers changing a spring with cheap spring clamps
