gear oil
loadlugger
gear oil
Post by loadlugger »
Is it ok to use 80/90 gear oil in my 1.8 petrol p reg.
jasper5
Re: gear oil
Post by jasper5 »
Should be 75w80.
Re: gear oil
If you put the 80/90 in there you probably won't be able to change gear until the oil warms up...
loadlugger
Re: gear oil
Ok folks, suppose I've got to buy some then :D .just that I found some at work for free which stated universal.
madmadmax
Re: gear oil
Post by madmadmax »
gl5 and copper safe is what is should be as the balk ring are brass and sum oils will melt them
