Limp mode and MOT
Posted: Sun Feb 10, 2013 10:18 am
by diddidave
Hi guys
Maybe a stupid question but my hdi has its Engine management light on and doesn't rev above 2800 rpm, I haven't had on a machine for a code yet as money's bait tight but would it go through a MOT with the revs being limited like that
Dave
Re: Limp mode and MOT
Posted: Sun Feb 10, 2013 10:36 am
I think you've had it for a start because the eml is on
Posted: Sun Feb 10, 2013 11:34 am
by diddidave
Pretty much what I thought, what sort of price are we talking to get it on a computer/code reader or what ever they are called or am I better off buying one off fleabay
Posted: Sun Feb 10, 2013 11:57 am
by rwb
Mine went through in limp mode, but that was in 2008. Got an advisory about not being able to rev above 2800.
If you're lucky you might find someone nearly with PP2000...
Posted: Sun Feb 10, 2013 12:01 pm
Perhaps if you put your location you might find someone nearby.
Posted: Sun Feb 10, 2013 2:21 pm
by madmadmax
go to the mot station and see if they will do you a deal on the coda read and the mot, my mot man will fit tires and do up nuts and bolts and do the mot for £50 and he charges £35 for the mot by its self.
Posted: Tue Feb 12, 2013 2:53 pm
by trufflehunt
My local independent garage charged me £35 to read the code, and reset the EML.
Posted: Tue Feb 12, 2013 2:54 pm
by jonsowman
trufflehunt wrote:My local independent garage charged me £35 to read the code, and reset the EML.
I'd've done it for a cup of tea
Posted: Tue Feb 12, 2013 10:54 pm
by Doggy
jonsowman wrote:trufflehunt wrote:My local independent garage charged me £35 to read the code, and reset the EML.
I don't even drink tea
Posted: Mon Feb 18, 2013 8:19 pm
by Sonia406
Can anyone with PP2000 do this reset? What causes the darn things to light up anyway? I.e IF I get PP2000 hooked up to it, and reset it, how likely is it that it will just come back on again?
Posted: Mon Feb 18, 2013 8:34 pm
by madmadmax
Sonia406 wrote:jonsowman wrote:trufflehunt wrote:My local independent garage charged me £35 to read the code, and reset the EML.
if you don't fix the fault that made the engine light come on it will come back over and over till the mechanical fault is fixed
Posted: Mon Feb 18, 2013 8:41 pm
by Sonia406
Could the ABS sensor cause the EML light to come on? Or the Air bag ECU electrics?
Apart from that my car is absolutely fault-less and I had it hooked up to PP2000 only 2 weeks ago and threw up only those 2 faults .... Seems silly for the EML to come on for those two though?
Posted: Tue Feb 19, 2013 5:00 pm
by madmadmax
do you know what the fault codes where as it will be one or both of them making the light come back on
the eml if for engine related faults only, so the abs being faulty would make the abs light come on.
