pug 306 petrol to xud conversion,
been looking into this for awhile anyideas what bits iwill need,
going to dump the petrol lump and throw a xud lump in ..shoe horn 2.1 in perhaps,.
so far shopping list is,
Tank and fuel lines,
exhaust,
mounts
hubs
loom?
what other bits will ineed ideas?
jonsowman
Re: pug 306 petrol to xud conversion,
Post by jonsowman »
I can't offer any advice myself, but I know KrisB has done this :) He might be along with some information.
cheers :wink:
madmadmax
Post by madmadmax »
thers a lot of info on pug306.net and 306oc is where you will find mr lobb(mr diesel)
Tbh. ifind some of the 306 forums abit of a mixed bag,
some good chaps on them but theres always the nobs,
ask aperfectly normal question on them and your bombarded with keyboard warriors,
its not worth the waste of wear and tear on the keyboard,
sorry if it causes offence but im just being honest,
Bailes1992
Post by Bailes1992 »
2.1 will drop straight in. Try get an engine loom from another 306 dturbo though.
I have a funny feeling the bulk head will need some beating to stop the turbo rubbing!
Fit a Bosch pump for veg oil!
And your likely going to need a subframe from a XU/DW or XUD engined 306 or Xsara.
I don't know if it'll give you any issues but the 2.1 is quite a heavy lump, the 2.1 406 uses the same springs as a V6...
Seems like a whole lotta trouble to me.
I always say you're best to buy something that left the factory the way it should be and then 'tweak' it a bit if you must.
The other risk you take is that once you change the engine you render the car almost worthless to the average buyer.
RobTurbo
Post by RobTurbo »
You don't need to change the tank, just replace the pump with a bit of pipe, that's all it is on a diesel 306 (I've done this swap the other way, diesel to petrol!)
I seem to remember someone fitting a 2.1 XUD into either a 205 or 306, can't remember which, and IIRC there was some problem with the turbo exhaust outlet being in the wrong place/hitting something, not very helpful I know, but it's something you can look into, it could have been a completely different engine :supafrisk:
Cheers
im going to crack on with it soon, 8)
just finnishing off bits and peices on my other toy,
its getting there, almost showroom condition, :D
midsmike
Post by midsmike »
That isnt a megane is it
yeah its a Meg.
its not to bad for a renault, pretty nippy,
bought it cheap as it had head gasket failure,
150 quid later and abit of work and its good as new,
its come from Bala'mena in ireland absouloute mint ball of a car,
the reg plate on it is worth more than the car, :D
Back ontopic of the 306.
ive been oferd an old xantia diesel, ithink its a N reg,
do you rekon all the running gear off that will swap over?
going to have abid on this for its running gear. http://www.ebay.co.uk/itm/1999-CITROEN- ... 3f21fd596b
1.9 shouid be good enough and its running on veg,
Bailes1992
Be better off with an Xsara.
The xantia is 406 based!
