Page 1 of 2
pug 306 petrol to xud conversion,
Posted: Sun Feb 10, 2013 11:38 pm
by lozz
been looking into this for awhile anyideas what bits iwill need,
going to dump the petrol lump and throw a xud lump in ..shoe horn 2.1 in perhaps,.
so far shopping list is,
Tank and fuel lines,
exhaust,
mounts
hubs
loom?
what other bits will ineed ideas?
Re: pug 306 petrol to xud conversion,
Posted: Sun Feb 10, 2013 11:42 pm
by jonsowman
I can't offer any advice myself, but I know KrisB has done this
He might be along with some information.
Posted: Sun Feb 10, 2013 11:43 pm
by lozz
cheers
Posted: Mon Feb 11, 2013 12:12 am
by madmadmax
thers a lot of info on pug306.net and 306oc is where you will find mr lobb(mr diesel)
Posted: Mon Feb 11, 2013 12:17 am
by lozz
Tbh. ifind some of the 306 forums abit of a mixed bag,
some good chaps on them but theres always the nobs,
ask aperfectly normal question on them and your bombarded with keyboard warriors,
its not worth the waste of wear and tear on the keyboard,
sorry if it causes offence but im just being honest,
Posted: Mon Feb 11, 2013 7:06 am
by Bailes1992
2.1 will drop straight in. Try get an engine loom from another 306 dturbo though.
I have a funny feeling the bulk head will need some beating to stop the turbo rubbing!
Fit a Bosch pump for veg oil!
And your likely going to need a subframe from a XU/DW or XUD engined 306 or Xsara.
Posted: Mon Feb 11, 2013 8:18 am
I don't know if it'll give you any issues but the 2.1 is quite a heavy lump, the 2.1 406 uses the same springs as a V6...
Posted: Mon Feb 11, 2013 1:06 pm
Seems like a whole lotta trouble to me.
I always say you're best to buy something that left the factory the way it should be and then 'tweak' it a bit if you must.
The other risk you take is that once you change the engine you render the car almost worthless to the average buyer.
Posted: Mon Feb 11, 2013 5:34 pm
by RobTurbo
You don't need to change the tank, just replace the pump with a bit of pipe, that's all it is on a diesel 306 (I've done this swap the other way, diesel to petrol!)
I seem to remember someone fitting a 2.1 XUD into either a 205 or 306, can't remember which, and IIRC there was some problem with the turbo exhaust outlet being in the wrong place/hitting something, not very helpful I know, but it's something you can look into, it could have been a completely different engine
Posted: Mon Feb 11, 2013 7:46 pm
by lozz
im going to crack on with it soon,
just finnishing off bits and peices on my other toy,
its getting there, almost showroom condition,
Posted: Mon Feb 11, 2013 8:58 pm
by midsmike
That isnt a megane is it
Posted: Mon Feb 11, 2013 9:19 pm
by lozz
yeah its a Meg.
its not to bad for a renault, pretty nippy,
bought it cheap as it had head gasket failure,
150 quid later and abit of work and its good as new,
its come from Bala'mena in ireland absouloute mint ball of a car,
the reg plate on it is worth more than the car,
Posted: Mon Feb 11, 2013 9:22 pm
by lozz
Back ontopic of the 306.
ive been oferd an old xantia diesel, ithink its a N reg,
do you rekon all the running gear off that will swap over?
Posted: Tue Feb 12, 2013 12:37 am
by lozz
going to have abid on this for its running gear.
http://www.ebay.co.uk/itm/1999-CITROEN- ... 3f21fd596b
1.9 shouid be good enough and its running on veg,
Posted: Tue Feb 12, 2013 10:15 am
by Bailes1992
Be better off with an Xsara.
The xantia is 406 based!
