My engine is making "the noise" that indicates I may well have a failed/failing pulley.
Any suggestions for the best place to get the part?
And will a 12v impact wrench shift the bolt?
Thinking of getting an electric wrench, decided against cordless and either going the 230v or 12v route. Any suggestions on brands etc?
2.2HDi crankshaft pulley - going to replace it
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
Re: 2.2HDi crankshaft pulley - going to replace it
i got a clark 230v electric one for about £60 for doing the job and shifted it no trouble
this is the one i got http://www.machinemart.co.uk/shop/produ ... act-wrench
just had mine off and on again with a (snap on) battery powered impact wrench borrowed from a local garage with no issues.
Been down to GSF and picked up a Corteco pulley and Dayco belt, then machinemart for a Clarke CEW 1000 - now the fun begins
406 Coupe S HDi
406 Coupe S HDi
Useful to know that once you have removed the inner liner, you can access the bolt (with an impact wrench) with the wheels on the ground on full right lock.
Or to put it another way, when my extension lead did not quite reach I put the wheel back on and drove the car closer to the power socket
406 Coupe S HDi
406 Coupe S HDi
