Gearbox diff seal!
Posted: Tue Apr 09, 2013 3:39 pm
by keppler
The driver's side gearbox diff oil seal has sprung a leak on my car (2000 HDI 110 BHP, RHZ). Now Ive changed diff seals on a few mates car's and it wasn't too difficult. I just took the driveshaft out of their gearbox's and the seal was exposed and simply removed and a new one tapped in. However when I was around at peugeot ordering a new one I could see on 'servicebox' what looked like a cover plate bolted on to the gearbox housing and some sort of cir'clip holding the seal in place.
Am I correct in this or is this gearbox the same as the others I have done in the past? ie just pull the seal out with pliers when the drive shaft is removed.
Anyone have any past experience with this particular job
cheers
Re: Gearbox diff seal!
Posted: Tue Apr 09, 2013 4:09 pm
by jasper5
Take out the driveshaft then unbolt the cover plate and remove it, tap out the old seal carefully then carefully tap in a new seal...be sure to note which way round the seal fits....there is no circlip holding the seal in place.
Smear a little grease onto the new seal lip and a little sealant onto the cover plate facing then refit everything.
I would drain the gearbox oil first...you will need 1.9 litres of 75w80 gear oil....refill from either the plastic breather screw hole or the reverse light switch hole.
Posted: Tue Apr 09, 2013 4:36 pm
by keppler
Cheers jasper5, just the info I was looking for!
Any recommendations on which sealant to use for the cover plate. Will any kind of instant gasket maker do? I already have a tub I used to reseal a leaky rocker cover with.
Posted: Tue Apr 09, 2013 4:50 pm
by jasper5
keppler wrote:Cheers jasper5, just the info I was looking for!
Use the stuff you already have, but be sure to only use a smear...you don't want any inside the gearbox!
