2.2 hdi 406
2.2 hdi 406
I have the old antI-pollution fault, and whilst looking in bay on the RH side, found a loose cable with a half yellow connecter, about 3cm wide.
it wasn't the maf or throttle cable, any ideas
2002 406 2.2 hdi glx estate
staffs
staffs
Re: 2.2 hdi 406
Is that rhs stading at the front of the car looking under the bonnet or as it would be sitting in the driver's seat? Any chance you can read any of the codes off of the wires?
Re: 2.2 hdi 406
Hi & welcome to the forum.
Bit difficult to visualise from your description, any chance of a pic or two?
Think the swirl flap solenoid valve is in that area, but they're not all the same. What year is the car?
Re: 2.2 hdi 406
standing over bonnet. 18 is the number and yellow with a blue band 3 cm from connector end.2002 plate.steve_earwig wrote:Is that rhs stading at the front of the car looking under the bonnet or as it would be sitting in the driver's seat? Any chance you can read any of the codes off of the wires?
hello to all as well.
I currently own a 2002 hdi 406 estate glx , bought with fault (anti-pollution) 4 weeks ago. so far changed fuel filter (after fitting incorrectly, then dropping and breaking it
List to do, going to change interior to leather one (bought already), defap and remap it, strut brace, Change rear drop links, cambelt and get some nice alloys over the next 6 months.
it runs just in limp mode.
I have owned 2 306 hdi's, a 406 2.2 hdi coupe (About 32 different cars in total)..so not adverse to frenchies..
cheers
staffs
staffs
Re: 2.2 hdi 406
A pic or some wire no.s, as steve says, would help - or a PP2000 diagnosis.
Could easily be a dpf issue and since you intend removing it anyway, maybe sooner would be better?
Sounds like you know the score, but feel free to PM me if you want any help.
Re: 2.2 hdi 406
cheers will get a picture tommorow. i ran a non fap non egr map and it was lumpy as hell so looks like a vac issue, but an unplugged cable is never good..Doggy wrote:A pic or some wire no.s, as steve says, would help - or a PP2000 diagnosis.
staffs
staffs
Re: 2.2 hdi 406
SO it's just got 1 wire in it? The number should be at least 4 characters, I just had a squint and numbers starting with 18 seem to refer to the particulate filter (but none of them just have 1 wire
Re: 2.2 hdi 406
Not something I've spotted on my 2.0... That's by the brake master cylinder? Can you push the tube back and read any numbers?
Re: 2.2 hdi 406
the only number is 8 . Had a look it is tied in with others, and won't reach far, it is next to the engine but can't see where it can go. A mystery?
staffs
staffs
- Captain Jack
Re: 2.2 hdi 406
Maybe the back/side of the brake fluid reservoir?
Re: 2.2 hdi 406
cut the cable sheath off and you will be able to get the wire code off it, pug used any color cable so the colors are not much use as they change from car to car so the 4 digit code is how to identify the wire
Re: 2.2 hdi 406
no wires codes after cutting sheaf, but on the connecter 5there is '01' and pbtmadmadmax wrote:cut the cable sheath off and you will be able to get the wire code off it, pug used any color cable so the colors are not much use as they change from car to car so the 4 digit code is how to identify the wire
staffs
staffs
Re: 2.2 hdi 406
Looking at the pictures, I'd hazard a guess that's your upstream dpf temperature sensor connector, (found this unplugged on my previous 2.2 HDi - curiously it didn't cause any problems without it)! You'll probably find the other half hanging between the two pressure sensor pipes.
The upstream sensor is in the cat housing, just after the flexible exhaust section, BTW
