How do I find out what bore my exhaust is?
Posted: Fri Jun 21, 2013 12:58 pm
by Sonia406
Hi everyone :D
Want to know what bore my current exhaust is.
I've looked on service box and can't find out.
Even Mr Haynes is being unhelpful.
I want to replace the backbox with something else, so need to know what bore my exhaust is so I can find out what will fit and what will need an adjuster.
I think it may be 2.5inches / 63.5mm but I got that information from an unreliable source, so wondered if anyone knew for sure what I'd have.
It's a 2.0 16v 5 door family estate (2001)
Cheers in advance
Re: How do I find out what bore my exhaust is?
Posted: Fri Jun 21, 2013 2:51 pm
If you are able to accurately measure the circumference..........
Say if it measures 179mm, then divide by 3.142 to give 56.97mm (diameter) then divide by 25.4 to give inches - in this case 2.25" or 21/4" (about the length of Puggy's penis for example).
I don't think yours will be 2.5inches more 2 or 21/4"
Posted: Fri Jun 21, 2013 3:25 pm
by Sonia406
Cheers Welly & :shock: :lol: Slightly worried how you know that about Puggy though :lol:
Posted: Fri Jun 21, 2013 3:41 pm
by puggy
so am i !! cheeky fooker , and you are miles off :twisted:
Posted: Fri Jun 21, 2013 3:52 pm
Ah, don't worry mate, it's not what you got... :twisted:
Use a piece of paper to measure it (the exhaust that is), wrap it around, mark where it crosses over & then measure that. Much easier than using a tape measure...
Posted: Fri Jun 21, 2013 4:58 pm
by Sonia406
steve_earwig wrote:Ah, don't worry mate, it's not what you got... :twisted:
Sounds better as I've lost my tape measure :lol:
Posted: Fri Jun 21, 2013 6:15 pm
by crackpotterpig
for measuring other things I personally always multiply the measurement by 1.5
Posted: Fri Jun 21, 2013 8:18 pm
by Doggy
Don't want to rain on your parade, but measuring the circumference is gonna get you the outside diameter, not the bore.
Posted: Fri Jun 21, 2013 9:41 pm
I was wondering when someone would spot that [/Cptn. Mainwaring] :cheesy: What is the thickness of the metal they use to make these pipes, couple of mil? Do you think it'll put the calculations out by much? :?
Posted: Fri Jun 21, 2013 9:52 pm
by Doggy
steve_earwig wrote: What is the thickness of the metal they use to make these pipes, couple of mil? Do you think it'll put the calculations out by much? :?
True, probably less than it'll expand climbing Prescott Hill......
Posted: Fri Jun 21, 2013 10:13 pm
by Sonia406
Doggy wrote:Don't want to rain on your parade, but measuring the circumference is gonna get you the outside diameter, not the bore.
Ha ha - oh yes :oops:
Posted: Fri Jun 21, 2013 10:24 pm
by dirtydirtydiesel
Shouldn't matter anyway, because if you plan on removing the back box & replacing it, your replacment pipe will idealy have an internal dia the same as the external dia of your pipe work :P , i.e : 60mm o/d std pipe work then 60-62 i/d replacment back box @ the join anyway. That is if you are using a u clamp for the join & not welding it :wink:
If you go down the u clamp route make sure you use a smear of exhaust ass paste on final ass, as this will expand with the hot gasess & make sure you have a gas tight seal 8)
Hope this helps. :cheesy:
Posted: Sun Jun 23, 2013 2:16 pm
by Sonia406
dirtydirtydiesel wrote:Shouldn't matter anyway, because if you plan on removing the back box & replacing it, your replacment pipe will idealy have an internal dia the same as the external dia of your pipe work :P , i.e : 60mm o/d std pipe work then 60-62 i/d replacment back box @ the join anyway. That is if you are using a u clamp for the join & not welding it :wink:
Ha ha - exhaust ass paste :lol:
Thanks, yeah I shall be using a clamp and this so called ''ass paste'' :lol:
Just have to decide which friggin' exhaust I want now, lol...........
Posted: Sun Jun 23, 2013 8:04 pm
by dirtydirtydiesel
:arrowu: :arrowu: :arrowu:
Sorry didn't know your mind was in the gutter, use Exhaust assembly paste. :cheesy:
