406 exe turbo 98, no start , solenoid i think , where is it.
Gracchi
Post by Gracchi »
Hi all, longtime no see, been a good winter for me baby,
but last week , shes had problems starting,now shes dead, battery seems fine, when i turn the key i just get a clicking noise coming from the engine, if i turn the key all way round , everything works, so dont think its the battery,
prob is from the key switch to the battery.
now ive meaning to buy the manuel for a long time but the local pugwoit dealer want 45 quid, specail manuel , from france they say.
cheers for any help.
i dont even know where the starter motor is , sorry .
jameslxdt
Post by jameslxdt »
have you tried a new battery?
Gracchi
Post by Gracchi »
no ,but i can still play the radio, lights and everything seem strong, no dimming, so i think it must be something else as when i tested the bat , it seemed ok.
Get a Haynes manual. Don't think there's anything in the Pug manual that you need to know that isn't covered by the Haynes as well, so it's definitely worth the money.
I'd try sticking a multimeter on the end of the lead(s?) to the starter motor and getting someone else to try turning the key (or using a 'max hold' feature if available). Could just be a dodgy relay...
Gracchi
Post by Gracchi »
Got a haynes manuel today, usless, for the exec anyway, all models in the manuel say the ignition coil is on top of the cylander head,, i carnt seem to find it,
so was wondering if anyone knew where it was.
and apart from the local pug dealer, and has any one brought one laterly?.,
cheers lads.
rewind, i got a new starter motor, 50 quid,put it on, now the car is turning over, but the engine is not kicking in. it kicked in once, blowing alot of smoke, i guesss thats the spark plugs, ill get them tomo.
ta
jameslxdt
Post by jameslxdt »
right, take one of the plugs out, plug it back in the ht lead, earth the centre electrode on part of the engine, turn the engine over, does it spark?
jameslxdt
Post by jameslxdt »
VERY IMPORTANT NOTE
dont touch the plug when your trying to start :P
Gracchi
Post by Gracchi »
have done all that, but will still not run, im starting to think it may be the immobilizer now stoping the engine turning, :evil:
any ideas?
o and thanks by the way.
jameslxdt
Post by jameslxdt »
did you get a spark?
do you have a keypad?
Gracchi
Post by Gracchi »
yes and no :D
jameslxdt
Post by jameslxdt »
if you are getting a spark, then obviously the coils are working :P
as you dont have a keypad then you wont have an immobiliser problem, usually the double relay is at fault and the fuel pump doesnt run, can you hear it running when you turn the ignition on?
Gracchi
Post by Gracchi »
the fuel pump seems to be working fine, can you tell me be abit more about the double relay please ,
excuse my ignorance.
jameslxdt
Post by jameslxdt »
the double relay triggers the coils, injectors, ecu and fuel pump, the ecu is working as the coils are working, so you are obviously getting no fuel, lift up the back seat, and get some one to listen to make sure the pump is working whilst trying to start, also listen to the injectors while trying to start and make sure they are ticking loudly, if not they may not be opening which could be caused by the relay
Gracchi
Post by Gracchi »
cheers man, all sorted now, was damp sparks,had to return them to the shop , got a new set and we are away.,
was just wondering about a service for me car,.diognostic and all that.
local stealer or a independent one?
and very many thanks for the help and info. :D
jameslxdt
Post by jameslxdt »
you may as well service it yourself as you will save yourself a tidy sum
