Clutch bleeding??
Posted: Sun Oct 20, 2013 10:05 pm
Hello All
I have a V6 coupe on an R reg that has the sealed clutch slave and master system. Over the past year the clutch pedal has been getting worse and worse. I have to pump the pedal quite a few times to get it in gear most of the time and the car tries to creep forward with the clutch fully down, it's especially worse on cold days.
I've had a look at diagrams of both the early and late systems and none of the parts are interchangeable as far as I can tell.
Has anyone found a way to modify the system to enable it to be bled?
I've considered adding a reservoir in place of the sealed fluid pot and drilling a small hole and tapping a screw in the back of the slave cylinder to to allow it to be bleed.
The system is no longer available from Peugeot and when it was it was nigh on £400. Anyone have any ideas as I don't fancy a second hand one. I don't want the Coupe to end up on the scrap heap because of this.
Thanks, Dave
(What were Peugeot thinking when they designed this?)
Thanks, Dave
