diesel partical filter 406
windy84
Post by windy84 »
hi ive a 03 406 90bhp,ive been having problembs with the anti pollution systm which engages the engine management this is happening est every 200 miles or so then switches off again after a while ..
this is a 2 part zust system so i presume the dpf is in with the cat??
can somone tell me how to check the cleaner fluid level and its location??
ive also just bought a fuel additive cleaner, might this solve the problem??
any other suggestions ...thanks mel
jasper5
Re: diesel partical filter 406
Post by jasper5 »
The 90 HP model does NOT have a DPF.
You should have a proper diagnostic check done using PP2000, if you post you location there may be a forum member in your area with PP2000.
Welcome to the forum BTW :D
I agree with Jasper, definitely no DPF. PP2000 will more accurately find the fault as the ' anti-pollution fault ' could be a number of things.
The 90 is a more basic engine with less complicated vacuums etc, so this should mean there are less things to spark up the fault.
Did you keep the receipt for the additive..?
Again, welcome and I hope the members here can guide you through your fault finding process.. :cheesy:
windy84
Post by windy84 »
:oops: cheers guys most helpful,,do have a garage, but enjoy a puzzel..
I think one of them might also tell you that before selling his 90 he found out it had a dpf...Sam?
