Hdi90 power loss
Posted: Mon Jan 06, 2014 8:16 pm
by charlie328
Hello, looking for some experience on this engine.
Car has recently lost power on uphill sections of motorway culminating today in an Engine Diagnostic warning light and frequent noticeable power loss to around 2000rpm which resets after a minute or so.
Are there any usual suspect components to cause these symptoms?
Thanks in advance, Charlie
Re: Hdi90 power loss
Posted: Mon Jan 06, 2014 8:21 pm
by Doggy
Hi Charlie and welcome aboard. 8)
Fuel and air filters OK?
What age is your car and do you know if it's got a Bosch or Siemens fuel system?
(The former has an in-tank lift pump and the latter a priming bulb under the bonnet).
Posted: Mon Jan 06, 2014 8:26 pm
by GingerMagic
Also, as a cheap diagnosis, try unplugging the MAF, its the black tube on the right between the air box and the corrugated bit - there will be a grey plug on it ( I think )
Posted: Mon Jan 06, 2014 8:34 pm
by GingerMagic
Oooops, maybe 90's don't have a MAF.... :oops:
Posted: Mon Jan 06, 2014 8:52 pm
by charlie328
Hello, I can't fing a priming bulb and can hear a lift pump with ignition so presume I have a bosch. The car is a 1999.
I disconnected the MAF and she wouldn't rev above 2000rpm?
Fuel filter is good. Air filter was dirty and the forward part wet. Going to fit a new one tonight but I blew it through anyway with compressed air. Could it be that simple?
Charlie
Posted: Mon Jan 06, 2014 9:08 pm
by markw
Someone on the Coupe forum unwisely drove through some deep water recently after all the foul weather we've been having.
He was suffering from almost exactly the same symptoms as you describe. He dried out the fair filter and it's been fine since.
Posted: Mon Jan 06, 2014 9:10 pm
by jonsowman
Just to clarify, 90s do have a MAF but it's only to monitor EGR function -- it isn't used for fuelling calculations. Unplugging it will still cause limp mode though, hence the not revving >2000rpm :D
Posted: Mon Jan 06, 2014 9:14 pm
by Doggy
charlie328 wrote:Hello, I can't fing a priming bulb and can hear a lift pump with ignition so presume I have a bosch. The car is a 1999.
It will be Bosch then. Lift pumps sometimes fail, but usually go intermittent for a while before dying.
Try the air filter first and let us know how you get on.
Posted: Mon Jan 06, 2014 9:51 pm
by charlie328
Hello again,
So, just replaced the air filter. Found water around the MAF and upstream which has been dried out now.
On closer inspection of the MAF it looks like we may have found the fault? There is what look like two little fuse wires which are probably sensors. One of them has broken and is missing. Can anyone confirm there should ordinarily be two or am I barking up the wrong tree on that one? going for a test drive anyway.
Really appreciate the help though, thanks.
Charlie
Posted: Tue Jan 07, 2014 10:04 am
by madmadmax
there should be two one for air speed and the other for air temp, so fined a siemens branded for as cheap as you can.
Posted: Tue Jan 07, 2014 11:00 am
by Busman
Does the HDI 90 have a throttle position sensor? This sounds remarkably like the symptoms mine had when that failed.
Posted: Tue Jan 07, 2014 11:03 am
by jonsowman
Where are you based? You could do with having fault codes read :wink:
Posted: Mon Jan 13, 2014 8:25 pm
by charlie328
Hi all,
Cleaned the water out of the inlet manifold, replaced the air filter and damaged MAF. She now pulls like a train with no warning light. Really happy. Thanks all for your kind help, much appreciated.
Posted: Mon Jan 13, 2014 8:28 pm
by jonsowman
Well done, glad it's fixed :wink:
Posted: Mon Jan 13, 2014 9:42 pm
by Doggy
Good stuff. 8)
