Vacuum leak?
Posted: Mon Feb 03, 2014 11:52 am
by benczuk
Hi All,
My brake pedal has been a little slow to rise up after pressing for a while now (pretty much ever since the cam belt was done around this time last year). You press the pedal and lift off and it takes a second or so for it to come back to meet your foot.
Recently the brakes have also started to feel a little weak the first use of the day, fine the rest of the time, and the car is also doing the "rev drop on slowing down for a junction when cold" (but only down hill??) mentioned in another thread.
Any suggestions on where to look or how to test for the cause of this?
Also would it affect fuel economy as that has been a little erratic recently, getting 45 one day and 40 the next on motorway runs ( but that could just be my on-the-way-out injector)
Re: Vacuum leak?
Posted: Mon Feb 03, 2014 1:27 pm
by Rolebama
I would be inclined to check the pedal return spring and the pedal pivot itself as a first step. Disconnect the master cylinder pushrod from the pedal to do this.
Re: Vacuum leak?
Posted: Mon Feb 03, 2014 2:06 pm
by madmadmax
i had this problem it was that most of the brakes need overhauling and the sliders need lubricating
Re: Vacuum leak?
Posted: Mon Feb 03, 2014 2:38 pm
by Captain Jack
Perhaps wouldn't hurt bleeding the brakes as well.
benczuk wrote:..the car is also doing the "rev drop on slowing down for a junction when cold" (but only down hill??) mentioned in another thread.
I had that on the 406 .. and only sometimes as well. No idea why it did it but never bothered me and never got worse.
Re: Vacuum leak?
Posted: Mon Feb 03, 2014 4:05 pm
by benczuk
Captain Jack wrote:I had that on the 406 .. and only sometimes as well. No idea why it did it but never bothered me and never got worse.
Aye, it doesn't bother me either, I mention it as it has been discussed here in connection with a vac leak recently..
Will give them a check / bleed as soon as it stops raining... :cry:
