Aux belt tensioner on a 2.2
I noticed a noise coming from the aux belt area last night, quite pronounced when the engine is warm but only a slight whine when cold.
My mate and I tracked it down to the tensioner so I'll be swapping it at the weekend amongst other jobs in the engine bay.
Looks to me a straight forward enough job but any tips/hints on changing them on the DW12 or pit falls to avoid?
Thanks in advance as always
- jonsowman
Re: Aux belt tensioner on a 2.2
Top man Jon,
As usual 2 minutes to change 30 minute faff to get at it!!!!
Funnily enough ECP has a couple of crank shaft pulleys listed and they are heavily discounted at the minute £50 to £90 for OE quality (there claim not mine).
The pics dont look like the one in the guide but it could be stock photos, I think I'll change the tensioner and have a good nosey at the pulley while I'm there and grab one if needed while they're cheap.
I just rang my LMF and he's got a Gates tensioner on the shelf for £37 which he's holding for me.
Out of curiosity I rang the stealers, not in stock but can be overnighted if I want it for an extra £5, tensioner cost £92.
He sounded a little put out when I asked if you got the rest of the car with it
- jonsowman
The OEM pulleys were either Dayco or Corteco depending on who you ask, maybe they both manufactured them.
They updated the pulley design due to them all failing, I believe the new design from Pug have three slots around the circumference rather than 2 on the factory fitted units.
I've also heard that some of the replacement pulleys have no slots due to being a completely different design altogether.
Mine's going to need changing soon and I'm determined to get either a Dayco or Corteco, but I'm not paying £150 from a dealer. But I do want to make sure it's not going to fall apart again in 3 years!
I put Gates everything, (including aux belt tensioner on your estate at about 165/170k if memory serves). Pretty sure it was about £40 (and needless to say you couldn't fault the original).jonsowman wrote:Mine's going to need changing soon and I'm determined to get either a Dayco or Corteco, but I'm not paying £150 from a dealer. But I do want to make sure it's not going to fall apart again in 3 years!
- jonsowman
Interesting, thanks for that. Maybe I'll whack a Gates one on there and see how it goes then, the estate's crank pulley is still fine and it's on about 215k nowDoggy wrote:I put Gates everything, (including aux belt tensioner on your estate at about 165/170k if memory serves). Pretty sure it was about £40 (and needless to say you couldn't fault the original).
The pulleys on ECP have no slots but as I said could be a stock picture, so the concensus is shop for a better brand then?
- jonsowman
The reason I was going on about Dayco/Corteco is that I've heard of so many of the cheap no-brand ones failing after 2-3 years.
So best to get a known good brand, and Gates appears to also be fine
Curiously the new tensioner I fitted (thanks Jon for the guide) was branded as Gates on the box but stamped on the actual part as Dayco.
This can mean either Gates are a manufacturer/distributor or my LMF put it in the wrong box.
Either way it would appear to be an OE quality part so I'm not bothered either way!
- jonsowman
Excellent, that's a result then. Glad it's all sorted!
