2.2 hdi injectors removal
Just a quick question can you remove the injectors from the 2.2 hdi without it dammageing ecu like the 2ltr 8v or are they same as the 407 1.6 hdi where you have to tell.the car your removing the injectors because i want to remove the injector tips and fit new ones
Re: 2.2 hdi injectors removal
removing the injectors has nothing to do with the ecu, i replaced the injectors on my 8v hdi and the ecu if fine. you if your lucky you just pull them out don't for get new seals to
